View Poll Results: Helpful???
Not at all
0%
Somewhat
50.00%
Good
50.00%
Great!! Thanks
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
DIY Sanding light lenses
Old 02-25-07, 05:41 PM
2OO4IS300
2OO4IS300's Avatar
Exclamation DIY Sanding light lenses
Fog Light Before
Meguiar's Sratch X
220 Grit Wet/Dry Sand paper
Bottle of water
1500 Grit Sand Paper
Store the sand paper in bucket of water to keep it good and wet
I had to use the 220 Grit first (NOT EVERYONE SHOULD HAVE TO, MINE WAS REALLY BAD) The white/clear film will start to appear. Just keep spraying water on the lense and continue to sand. I thought it would be a fast process but taking your time and being patient really pay of.
Here's the light after I finished. Notice there is still small scratches and pits. I could not find 2000 grit sand paper at the hardware store so 1500 is the best I could find. Use 2000 to finish even nicer.
Any questions PM me!!! Or reply with other suggestions...
Old 02-25-07, 06:04 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
im assuming that there are pics in ur post that just dont want to show up
Old 02-25-07, 06:06 PM
PureDrifter
BahHumBug
Cool
Originally Posted by 2OO4IS300
Fog Light Before
Meguiar's Sratch X
Bottle of water
here
Old 03-06-07, 12:05 AM
JeffTsai
JeffTsai's Avatar
Nice, I use a slightly different method and do it with an porter cable orbital polisher. Trust me...it's waaaaay faster
All time figures below with electric polisher.
-Sand with 400grit, move to 600, 800, 1000, 1500, and finally 2000 (2-4mins each)
-Use foam polish pad in junction with turtle wax deep cut rubbing compound until it won't get any smoother (approx 5min with electric polisher).
-Wash off foam pad and use turle wax swirl remover polishing compound (5min)
-Wash off foam pad and use Novus Type 3 heavy scratch plastic polish (5-8mins)
-Use polishing pad and use Novus Type 2 light scratch polish (5-8 mins)
-Spray Novus Type 1 plastic cleaner/protection coating
My process is very very time consuming, but it pretty much makes the headlights look like new
Old 03-13-07, 05:53 PM
huerdo623
huerdo623's Avatar
I tried that with my cousins car and they came out worse than before.What did I do wrong?
Old 03-15-07, 02:44 AM
JeffTsai
JeffTsai's Avatar
You didn't follow all the steps all the way. Most likely you stopped at 2000grit sandpaper. The headlights will look completely white out after 2000grit sanding. You need to do some serious polishing to get the shine back.
Old 03-15-07, 03:14 AM
huerdo623
huerdo623's Avatar
Default Thanx Jeff
You are right Jeff, I didn't do all the steps I did the wet sand up to 2000,then I used the mequires plastix cleaner. Now I will pull them apart and use the instructions you posted.
Old 03-15-07, 01:34 PM
sinister2c
sinister2c's Avatar
I usually use a high speed buffer after sanding with meguiars polish...gives it that clear brand new finish.
Old 03-15-07, 02:04 PM
thanhvu
thanhvu's Avatar
cooool....thanks for this...my headlights are starting to go bad....
Old 03-16-07, 09:06 PM
huerdo623
huerdo623's Avatar
So do you use that Mequires scratch x to polish the lens with? Cuz the lens looks like the cloudy one farther up in the thread.
Old 03-18-07, 01:38 AM
milky
milky's Avatar
wow nice improvement..
Old 03-18-07, 10:54 AM
T.K.O.
T.K.O.'s Avatar
very nice, lookin slick
Old 03-18-07, 08:15 PM
LexFather
Guest
Posts: n/a
Fog Light Before
Meguiar's Sratch X
Bottle of water
Thank you.
Old 03-22-07, 07:30 PM
mike.gani
mike.gani's Avatar
Is this steps apply to all headlamps lenses?
Will the scratches in the lenses could be vanished? so, mm actually, what are those number of the sand papers (400,600,etc) represent to?
(Sorry I ask so many question because I don't know much about automotive T.T but I want to start learning though.)
thanks.
Old 03-22-07, 08:00 PM
emoshun
emoshun's Avatar
mike.gani, the numbers relate to the coarseness/fineness of the sand paper. For example, you start with low number grit, like 800, and work your way up buffing out fine lines, and scratches until you reach 2000 grit paper, which is the finest grit. Its best to hit every level of grit 800 (2-3mins), 1000 (3-5mins), 1500 (5mins), and finally 2000(5mins)...Remember, the higher the grit, the more time you must spend to get the lens clear again! Sand straight too!
Quick Reply: DIY Sanding light lenses
