Can some confirm my hack? DVD or Bluetooth bypass '07 RX350
Old 07-12-06, 01:24 PM
ScareyH22A
ScareyH22A's Avatar
Default Can some confirm my hack? DVD or Bluetooth bypass '07 RX350
This should disable the DVD and or Bluetooth lockout while driving. Do I need to tell you how dangerous watching movies while you drive can be?
26 pin plug behind the Multi Display
Old 07-16-06, 05:12 PM
jasonw
jasonw's Avatar
yes it seems to work...do you know how to disable the navigation lock out as well?
Old 04-09-07, 07:27 AM
jerfitz
jerfitz's Avatar
In your post, https://www.clublexus.com/forums/sho...d.php?t=226825
you show a picture of a 26 pin connector plug M5.
I have the Lexus repair manual for the 2007 ES350 and cannot find connector M5 in that mauual.
Is the M5 you show an M5 connector in a RX350? I sure would like to find the same spot in the ES350.
JerFitz
Old 04-09-07, 07:51 AM
geko29
geko29's Avatar
Bluetooth hack worked great for me. DVD playback doesn't work at all now though. I'll have to take it apart and re-ground it, I probably have a bad connection.
Old 04-09-07, 03:10 PM
jerfitz
jerfitz's Avatar
Will this hack work on a 2007 ES350 with NAV and Mark Levinson???
JerFitz
Old 04-10-07, 09:16 AM
RC_Av8r
RC_Av8r's Avatar
geko29,
What car do you have?
Thanks,
Dave
Old 06-29-08, 08:49 PM
sforeman00
sforeman00's Avatar
does this work with the '08 RX350 w/Backup Camera. I had heard there were additional changes needed to keep the camera working.
Old 06-30-08, 09:54 PM
geko29
geko29's Avatar
Originally Posted by RC_Av8r
geko29,
Thanks,
Dave
2007 RX350 Premium Nav/ML.
Old 07-01-08, 10:18 PM
turbosw20
turbosw20's Avatar
Hey will this work as well for the 330 or is it just for the 350?
Old 06-25-09, 12:58 PM
AMoosa
AMoosa's Avatar
I have a 2007 Rx400h SE-L and had a go at this hack. The plugs on the back of my stereo look completely different to the one described on this hack. Can anyone help and tell me which wires to mod?
Old 06-12-10, 09:43 AM
wmstewart
wmstewart's Avatar
Just did this on my 08 RX 350 and worked perfectly. All colors and wires matched the diagram.
Thanks!
Old 01-13-11, 02:52 PM
kbailie
kbailie's Avatar
I also tried this on my 07 RX350 and while I get bluetooth to work while driving, DVD doesn't work period now in the front.
Old 08-27-13, 10:25 AM
lormaichi
lormaichi's Avatar
hack worked on my rx400h Australian model only difference is that their is no red wire but a sky blue wire on the bottom of pin 20 and all the other cables are the same
everything works fine except for navigation that is still locked out
lexgolf
04-13-14 10:18 PM
dontat
ES - 5th Gen (2007-2012)
09-04-10 08:02 PM
wboy
10-04-07 09:39 AM
bturkel1@v
04-10-07 05:32 PM
Faridoon
03-03-07 09:16 AM
Quick Reply: Can some confirm my hack? DVD or Bluetooth bypass '07 RX350
