Windshield wiper fluid motor install for Rx300 Instructions.
Old 04-19-05, 10:14 PM
dmc888
dmc888's Avatar
Default Windshield wiper fluid motor install for Rx300 Instructions.
Part cost me 82 bucks for the part.From the dealer. Wasn't too hard to change.
Located in the front passenger side wheel well.
Pull plastic out near the front corner. Wheel well plastic cover.
I didn't need to unscrew anything.
But it might be safer if you don't want to chance cracking the protective plastic.
You should see the motor right in view.
Unplug harness first.
Then pull motor outwards away from the fluid tank. Kinda hard to pull out.
I let my fluid spill all out to flush any debris.
Also poured another cup just incase.
Use a razor and cut the tubing.
Then i used my electric car compressor and stuck each hose in it and flushed it out. About 5 min each.
It was clogged pretty bad.
Then put the hoses on the new pump.
Push the new pump in place.
Plug in harness.
Add fluid and check for leaks.
Took me 20 minutes.
Old 04-20-05, 08:36 AM
jimmouse
jimmouse's Avatar
Thanks for the instructions. My 2001 RX has some problem with the rear one. Is that a different motor than the one you installed? Mine sometime works, sometime not at all. I have not figure out why yet. You may give me a hint, please?
Old 04-21-05, 10:01 PM
dmc888
dmc888's Avatar
There is only one windshield washer fluid pump. Atleast for my 99. Should be the same.
It has two outputs.
Larger hose for the front and smaller for the rear.
If you open the panel and take a look you should see the two hoses on the pump.
You would have to cut the smaller one off with a razor. You can try pulling it off but mine was stuck on good.
Becareful not to cut the pumps hose connector. Should see the bulge.
Use a electric air compressor and stick the hose inside where the tire valve would go and lock the hose inside the attachment.
I have a air compressor in every car i own. I use it when i plug a tire,and routine inflating. Most i see are around 20-30 bucks. A must have in any car.
Run it about 5 minutes. Mine made a wierd whistling noise for the rear.
Also for the front when i had air going thru i took turns covering the driver and passenger side nozzles with my finger so it would build more pressure for the one not covered..
Old 04-27-05, 06:38 PM
tmuti13
tmuti13's Avatar
thanks guys, dmc, your instructions are great. i will take a look at it this weekend. where did you order the part?
Old 04-27-05, 08:22 PM
dmc888
dmc888's Avatar
Heres are some pics to make it easier. Passenger side wheel well plastiic cover. I am able to open with just my fingers. Although it pinches pretty good. Plastic seems to be good quality unlike others that crack easily.
Old 04-27-05, 08:23 PM
dmc888
dmc888's Avatar
Pump pic. Large hose for the front on the left side and small hose on the right for the rear.
The Left hose is suppose to be tucked behind the tranny cooler but i pulled it out for a better pic.
Also the pump is sealed with a rubber gasket, it looks well made so don't worry about breaking in when you remove the pump.
Old 04-29-05, 07:04 AM
tmuti13
tmuti13's Avatar
thanks again dmc, you are the man
Old 10-29-05, 10:43 AM
blk99rx300
blk99rx300's Avatar
Thumbs up Highlander pump source
To add to this thread, I used the Toyota Highlander pump to replace my RX300 pump that failed. The part number is 85330-20470, $30 cheaper and is identicle to the 85330-14490 part it replaced. Hope this helps.
jpajya (10-11-21)
Old 10-30-05, 03:43 PM
bizzy928
bizzy928's Avatar
Great thread guys!
Old 12-14-05, 11:34 AM
dreamdream
dreamdream's Avatar
Found one from autozone , TAAP PUMP - WINDSHIELD WASHER, part no. 5-768. Can it be equivalently used?
MarkG2000 (03-05-17)
Old 01-31-06, 12:25 PM
jimmouse
jimmouse's Avatar
Dreamdream, did you get that pump from autozone to work? I am looking for one also now. For those who changed the pump, where did you guys buy it? THANKS A LOT!!!
Old 03-08-07, 11:47 AM
wcody
wcody's Avatar
Default Autozone Part 5-768 doe NOT work
The Autozone part is NOT a replacement for the RX washer pump. It only has ONE outlet for fluid. Too bad - it's only $17. I had to get my replacement pump (PN 8533-14490) from the Toyota dealer. $79 (ouch). But that's a lot better than the Lexus dealer who wanted to charge >$200 for it installed.
Old 03-09-07, 11:08 AM
Brick
Brick's Avatar
If I remember correctly Irontoad was about $42 for the pump.
Brick
Old 03-09-07, 05:36 PM
Fern
Fern's Avatar
blk99rx300,
very useful post
Old 03-09-07, 08:27 PM
Lexmex
Lexmex's Avatar
On a kind of similar subject, my cousin and I plan to make a modification to lift up the windshield washer fluid reservoir tomorrow, so that the tranny cooler has better flow. May try to reposition the tranny cooler as well (bring it a little more forward)...will post pictures tomorrow once it is done.
Attached Thumbnails Windshield wiper fluid motor install for Rx300 Instructions.-img_2202.jpg
Quick Reply: Windshield wiper fluid motor install for Rx300 Instructions.
