question about TPMS for 06GS
Old Jan 16, 2005 | 12:43 PM
frebay's Avatar
frebay
Default question about TPMS for 06GS
does anyone know if the new 06 tire pressure monitor sensor will show the psi of each individual tire like the new RL or will it just alert you when there is a drop in psi?
Old Jan 16, 2005 | 12:59 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Toyota and Lexus uses an alert system and dash indicator.
Old Jan 24, 2005 | 01:41 PM
Lextranny's Avatar
Lextranny
Yes,.....Lexus does give you a indicator light on the dash...BUT....it sucks cause' it doesn't tell you which tire it is.
Unlike, Acura it shows you a picture on the dash with the exact tire that needs air!!!
Old Jan 24, 2005 | 02:29 PM
frebay's Avatar
frebay
so you get an alert, and you have to check every single tire? doesn't that sound counter intuitive
Old Jan 24, 2005 | 02:58 PM
CK6Speed's Avatar
CK6Speed
Yes, it is better then nothing, but not the best. It uses the wheel sensors and measures a difference in rotation between the wheels. Anyway, the system is a little useless if all of your tires loose pressure at about the same rate since it can't detect a difference in rotation speed. I've had slightly low pressure in a tire or two before and the TPMS on my 04 never detected it at all. I think it has to be really low and not just a few psi low before it knows what's going on.
IS350AWD
Jun 29, 2013 02:49 PM
kl323
Jan 4, 2013 02:50 PM
fiddlerjoe
Sep 10, 2012 04:19 PM
LIMS407
Jan 24, 2011 07:07 PM
sf7307
Mar 24, 2008 09:48 AM
