Lexus Towing Package wiring harness part number
Old May 15, 2026 | 08:02 PM
dbsoccer's Avatar
dbsoccer
8th Gear
Default Lexus Towing Package wiring harness part number
I have a 2019 RX-350 Base. It did not come with a factory towing package. I've added a 3 party receiver hitch - primarily for a bike rack. I am considering adding the wiring needed for trailer lights in case I may want to tow a very light/small trailer in the future. Does anyone have any information about the OEM wiring harness that was included as part of the factory towing package?
Old May 16, 2026 | 04:54 AM
Jacket's Avatar
Jacket
https://www.clublexus.com/forums/rx-...age-model.html
Old May 16, 2026 | 09:12 AM
Clutchless's Avatar
Clutchless
Or just look at https://www.etrailer.com/
You may find it easier to work with an aftermarket solution.
Old May 16, 2026 | 03:11 PM
Brut4c's Avatar
Brut4c
This worked perfectly in my '22. Easy plug and play.
Amazon Amazon
Old May 16, 2026 | 07:24 PM
dbsoccer's Avatar
dbsoccer
8th Gear
I had an online "Chat" with someone from eTrailers. She told me that not all RX-350 have pre-wiring for trailer lights. My RX does not have the towing package but I would have thought that Lexus would not create two different wiring harnesses - one for cars that will not ship with the towing package and a second harness for cars that will ship with a towing package. To me this is not logical as it would cut flexibility during the manufacturing process. I tried to explain that people on this forum have done what I am trying to do - at least I think it has been done.
So I'm trying to determine if the person at eTrailers is correct or not. I quickly slid under my car and I did not find a connector that looked like it was trailer light pre-wiring. Maybe I didn't look in the correct place. I like the eTrailer solution but until I resolve this question I'm, obviously, not going to order anything.
Thanks for all the rapid feedback. Much appreciated.
Old May 16, 2026 | 07:57 PM
dbsoccer's Avatar
dbsoccer
8th Gear
I found in my owners manual that, for cars without the towing package, Lexus does not recommend the installation and/or use of a receiver hitch. This even applies to a hitch used for a scooter, wheel chair or bicycle rack. Hmmm? I wonder if a top mounted ski rack is okay? Or a bike rack on the top. Or a car top tent. Or how about putting 10 50 lbs. bags of potting soil in the back? If it is a load/weight/cooling issue having the weight in the back of the car versus attached to a trailer hitch is the same. In fact if the tongue weight is properly set, the amount of extra weight on the rear axle would be much less than the extra weight pm the rear axle from say ten bags of of cement I'd buy from Home Depot (assuming a reasonably sized trailer). An issue braking with the extra weight would be the same. An argument could be made, perhaps, with suspension issues and the tendency of towing a trailer to cause swaying.
Old May 17, 2026 | 12:41 PM
Brut4c's Avatar
Brut4c
Op I also do not have the towing pkg, but the wiring is there. Look above the drivers side exhaust tip for a small grey cube. That’s the 4flat connector. Then, inside the cargo area look next to the spare tire. Passenger side back corner under the little cubby box. There should be a white plug for the relay box.
Old May 17, 2026 | 03:28 PM
dbsoccer's Avatar
dbsoccer
8th Gear
Thumbs up
Thanks Brut4c. A reply can't get any better than yours! Great pictures. Thanks for your extra effort to take those pictures. Much appreciated.!
CommodoreAmiga
RX - 5th Gen (2023-present)
69
May 14, 2026 11:53 AM
mnoone
NX - 2nd Gen (2022-current)
20
Feb 19, 2025 10:16 AM
DoDo1975
RX - 4th Gen (2016-2022)
Apr 4, 2024 09:01 PM
