Gps fired after jump start 2014 lexus is350 f sport awd
Old Apr 29, 2026 | 10:04 AM
bartucelik's Avatar
bartucelik
Default Gps fired after jump start 2014 lexus is350 f sport awd
Battery was dead I jump started the car then gps signal lost shows wrong location and signal comes sometimes after 20 minutes drive sometimes next day corrects itself
anybody knows where is this gps reciever located?
Old Apr 29, 2026 | 04:47 PM
kj07xk's Avatar
kj07xk
IIRC, it’s located just under the top of the dash, near the center speaker, but I don’t think it’s accessible without pulling the dash.
My GPS went out last year (IIRC) and the only way to get it back was to physically remove and restore power to the radio (I described in a thread somewhere here that I now power the radio from a relay on the ignition circuit, so the radio gets physical power removed on shutdown and restored on start up).
When your GPS is not working, and the car is running, try pulling the radio fuse, and then plug it back in. Wait about 5 minutes for the radio to restart and acquire GPS signals, to see if you now have accurate map data.
Old Apr 29, 2026 | 04:55 PM
Nkv92's Avatar
Nkv92
1st Gear
question I have an 08 Lexus is250 with 120000 miles when I’m driving and let of the gas the idle hangs around 1200 rpms then doesn’t downshift u til I slow down. My car rumble aometimes when it’s going through the gears. Is it the torque converter or do you think the transmission oil just needs to be changed a few times a drain and fill. I bought the car used like a month ago.
Old Apr 29, 2026 | 05:01 PM
bartucelik's Avatar
bartucelik
thank you , I will try
Old Apr 29, 2026 | 07:25 PM
kj07xk's Avatar
kj07xk
You should post your question in the Gen2 forum, this is the Gen3 forum.
Brodyhaskins
Performance
Jul 2, 2025 06:57 PM
Adamthefirst
Oct 27, 2024 07:27 PM
mhubbss33
Dec 23, 2022 01:03 PM
DaddyBTC
Performance
Mar 29, 2022 12:53 PM
kwsrxa
Apr 15, 2015 11:17 AM
