Water Pump 2GR-FE
Old Mar 29, 2026 | 06:49 PM
koushikmurali's Avatar
koushikmurali
10th Gear
Default Water Pump 2GR-FE
Hello all, I have a 2015 ES350 thats about to hit 100k. I know im supposed to do a coolant flush with the service, but should I also replace the water pump given the amount of failures reported on this engine? I am on the original pump and am in the southern USA so hot summers coming up. I understand the "if its not broke, dont fix it" mindset but I also have a 2000 mile round trip coming up in about a month and definitely do not want to get stranded because my pump went out. What are ya'lls thoughts on preventative water pump replacements on these engines?
Old Mar 30, 2026 | 12:31 AM
ESh's Avatar
ESh
I replaced the WP at 72000 miles. It was perfectly fine but I did not want to risk.
It is not easy to replace it while the engine is under the hood but it is doable.
Old Mar 30, 2026 | 07:28 AM
Clutchless's Avatar
Clutchless
If it is quiet and not leaking I would leave it alone and just change the coolant.
This job takes a skilled shop about 5 hours and they have to loosen up motor mounts to move the engine up or down a bit to get at all the bolts. There is little room to work.
Old Mar 30, 2026 | 09:21 AM
sveris's Avatar
sveris
Wouldn't you normally replace the water pump when you change the timing belt? No point in paying for labor multiple times unless it's necessary.
Old Mar 30, 2026 | 09:31 AM
koushikmurali
10th Gear
Its the 2gr-fe, its run by timing chain. water pump is run by serpentine belt, i do have to replace belt soon anyway
Old Mar 31, 2026 | 02:26 AM
rmak's Avatar
rmak
My 2016 has around 109k and I just purchased a water pump as well as tensioner and idler pulleys during the last Bell Lexus sale. My issue was elevated temps at idle in traffic. After bleeding the system properly, which I did not do after thermostat change, my issue went away. I will still change the pump etc. in the next few thousand miles just because I have it now. There are several good videos online about changing it. It does show that the right motor mount needs to be loosened.
kalvink
RX - 4th Gen (2016-2022)
14
Feb 8, 2024 09:59 AM
Forgetit
Apr 11, 2022 03:44 PM
Forgetit
Apr 11, 2022 01:55 PM
Lexi66
May 18, 2016 07:28 PM
kur1j
Nov 5, 2014 10:54 AM
