Delco Gold/Performance starters
Old Feb 26, 2026 | 11:01 PM
Stairstars's Avatar
Stairstars
6th Gear
Default Delco Gold/Performance starters
Hello,
Having to replace the starter on my 1997, as I am getting the dreaded single click. Very new premium battery and just for luck I replaced the starter relay looking for a miracle.
I had the desire to only buy a new starter, but finding a factory one seems to be impossible from all my local dealers (even Toyota) and the large CA and MA based online retailers. I did find that Delco makes a new one under the Gold/Performance line. One shop owner denigrated them by saying they reuse the housings, but all the guts are new. That does not bother me and they are reasonably priced. Anyone here have experience with that or want to offer an opinion?
Also, what gaskets should I get to do this job right? I also expect to replace vacuum lines that are old and brittle. Any suggestions there as well as the plastic connectors?
Any help appreciated.
rick
Old Feb 27, 2026 | 01:25 AM
Rockauto has a reman Denso why torture yourself with questionable parts
https://www.rockauto.com/en/moreinfo...t=4152&jsn=422
discount code
https://www.toyotanation.com/threads...360084/page-28
Old Feb 27, 2026 | 07:47 AM
Stairstars's Avatar
Stairstars
6th Gear
Thank you for your response.
I am a bit down on rebuilt, as Lexus of Nashville installed one in this car 50,000 miles ago for the second owner, which is why I am looking for a new one. I do not want to go through this again.
Old Feb 27, 2026 | 08:33 PM
joewitafro's Avatar
joewitafro
1997 SC400, you can order one from a lexus online dealership part # 28100-50062-84.
If you check parts.belllexusnorthscottsdale.com, you can find one for $169 from Arizona, they have never done me wrong and I've ordered a lot across the US. Most of the reason these die is oil contamination or heat, and the location of the starter on the SC400 doesn't help but they should definitely last more than 50k miles.
Old Feb 28, 2026 | 10:30 AM
Stairstars's Avatar
Stairstars
6th Gear
Thanks.
I went ahead and ordered from Rockauto everything needed, including the gaskets, seals and just in case, an assortment of vacuum hoses for old and brittle ones.
And, just for accuracy, the starter sold in AZ is remanufactured, as well.
https://parts.belllexusnorthscottsda...005006284.html
JuanVargas
May 11, 2024 11:04 AM
mdrag
Dec 15, 2015 03:40 AM
raphytaffy
17
Jan 8, 2015 04:21 PM
mcbalagtas
Dec 6, 2012 02:36 AM
SuicidnS13
Nov 2, 2010 08:51 AM
