Polished Trans Cooler
Old 12-27-02, 09:27 PM
Pearlpower
Pearlpower's Avatar
Default Polished Trans Cooler
Some have asked for a pic. Here they are.
B&M racing cooler. Compact,yet thick to compensate for it's size. Anodized Blue connectors, stainless steel polished 3/8" #6 line. Custom bracket.
Old 12-27-02, 09:30 PM
Pearlpower
Pearlpower's Avatar
Default Installed
Here is the unit installed. Note, it uses the factory mount on the top left, with a custom bracket on the right.
Does it work?
Temp gauge and also the pyrometer shows that it cools slightly better than the larger units without any of the cooling issues.
The trans is safe and it looks sweeet through the grill.
I installed one on a buddies black GS last night and it stands out even better with his black grill. It was too late for a good pic though.
Old 12-27-02, 09:35 PM
Pearlpower
Pearlpower's Avatar
Default A POSE
Here is the unit prior to install.
No leaks ever with this setup
Old 12-27-02, 09:38 PM
Pearlpower
Pearlpower's Avatar
Default a side view
Side view shot
Old 12-27-02, 09:45 PM
Pearlpower
Pearlpower's Avatar
Default Line1
Line 1 polished 3/8 " #6, stainless steel lines
Note the connectors.
Old 12-27-02, 09:47 PM
Pearlpower
Pearlpower's Avatar
Default Line 2
A bit more elaborate on the bends
Old 12-27-02, 09:49 PM
Pearlpower
Pearlpower's Avatar
Default Steel line
I will be connecting both steel lines together with a braided steel line. Till then, only 5 inches of rubber hose is perfect.
Old 12-27-02, 09:59 PM
Pearlpower
Pearlpower's Avatar
Default Holes
There are few ways to route lines/hoses. We tried going around the condenser/radiator but found the temperature was elevated there and we did not want the hose to touch these componenets though no harm would probably come from it. Plus it used more hose than we wanted since it is going around and back. Another spot is under and on the side of the passenger side, but once again the install did not look clean and we did not want the hoses to rub on anything. Also steel lines would not have been able to make it.
We obted instead to drill two holes on the plastic air flow shroud as pictured. Nothing is behind it ,so there is not need for worry. The holes are clean and look factory/professional with a minimal of line/hose use with the added benefit of not touching/rubbing on anything hot.
Also this spot is perfect because even if the car bottomed out and hit the front end, the lines/hoses are well protected from the front crossmember.
Also the engine cover covers the lines nicely so nothing is exposed.
You guys be the judge.
Old 12-27-02, 10:53 PM
///MDex
///MDex's Avatar
BLING BLING!
J/K
I prefer the black, more stealthy look (http://www.digitalsimple.com/PCTC%20Installed.htm), but your's is surely a great install; looks sharp, and great info, and thanks for sharing.
Old 12-27-02, 11:09 PM
Pearlpower
Pearlpower's Avatar
Default The look
Hello Dex
Thanks.
The last few coolers I had had similar installs but were in all black. Looked too factory for me and I wanted something that stood out which I believe this does. But hey, a can of engine black will take care of it if one wanted.
LOL.
Old 12-28-02, 01:14 AM
Ag02M5
Ag02M5's Avatar
What is the cost/model #?
Thnx.
Ryan
Old 01-12-03, 02:56 PM
Received 2,252 Likes on 1,465 Posts
How's my tranny cooler kit coming along pearlpower?
Old 01-13-03, 01:47 AM
Pearlpower
Pearlpower's Avatar
Default Nice
Paul
Check your email for the good news
Lee
Old 01-13-03, 12:11 PM
BananaGS
Tech Guru
BananaGS's Avatar
my cooler is black
I like bmracing design, very low pressure drop compare to all of the other trans cooler i've seen. Also, the cooling fins are 100% solid.
Old 01-13-03, 02:41 PM
redgs4
redgs4's Avatar
That looks really sharp, have to say I like the polished cooler over the black. Thanks for the writeup on your line/hose routing -- I hope to do something similar soon.
I'm not sure on routing through cut-outs in the shroud, though, without having crawled underneath the car, but I was wondering about shroud deformation under load. I suppose if you smack something that hard the cooler lines are one of many things to worry about.
Quick Reply: Polished Trans Cooler
