Roof folding in SC
Old 10-21-15, 10:37 PM
GmanSC
GmanSC's Avatar
Thanks for the Infos. It really helps.
Old 10-21-15, 10:42 PM
GmanSC
GmanSC's Avatar
Thanks for the Infos. It really helpful.
Old 10-27-15, 12:34 PM
Coleroad
Coleroad's Avatar
Just one more thing I forgot to mention. The parts I sprayed with the silicone lubricant. I would do that once a month. It's not thick and doesn't last as long as a grease. The upside is like I said doesn't attract dust and dirt, because it dries to a slippery film. The main gear with the grease you should only have to do once a year.
Old 05-01-16, 04:13 AM
ruger
ruger's Avatar
Originally Posted by ShawnOk
I've had my car for 13 years now and never had a top problem. I drop the top as much as I can, weather permitting. I do service it pretty often to try to keep it problem free. I grease the gears every year or so, and oil all the moving joints and parts. I also lubricate the rubber gaskets. A little maintenance that truly pays off for years of function, for sure.
Do you turn on motor, start top to open to the point where you can lube parts, then remove finger from
open button at that point and shut off motor?? When your done, turn on motor and push open button again?? please reply..
Old 05-01-16, 06:27 AM
Coleroad
Coleroad's Avatar
That is how I do mine
Old 10-11-18, 03:21 AM
gbdad
gbdad's Avatar
Coleroad thanks for the lube pics, very helpful!
Old 08-14-22, 07:30 PM
whlng88
whlng88's Avatar
Originally Posted by Coleroad
Moving further to the rear is the main gear and drive. The drive gear looks to be plastic. I would use white lithium grease or I used a high temp ceramic grease that is also plastic safe. After I took the picture I did wipe up the grease I got on some of the surrounding areas.
Hi Coleroad & GManSC,
Per Google search, it says lithium grease is not advisable for plastic parts ? But instead silicone grease is recommended?
Thanks
Old 08-15-22, 10:03 AM
GmanSC
GmanSC's Avatar
Thanks
I used lithium grease on metal and silicone lube on plastic parts.
Old 08-15-22, 05:28 PM
whlng88
whlng88's Avatar
Great. Many thanks
Old 08-17-22, 11:24 AM
jimisbell
jimisbell's Avatar
I wonder how much of this is "Tiger Powder" Just sprinkled it around my house 20 years ago and havent seen a tiger since.
My car is 14 years old and havent seen a problem yet, someone must have greased it when I wasnt looking..............
Old 08-17-22, 11:29 AM
Raven01750
Raven01750's Avatar
Not much you can do about the hydraulic pump. The seals in the pump wear. And the motor that runs it. All we can do is make it as easy as we can on the pump and motors.
I have read this post a couple of times now and me thinks you are in the Mercedes Forum too. Our cars do not use hydraulics for the roof. Just electric motors and ECU's. Am I wrong here? Thanks.
Paul
The following 2 users liked this post by Raven01750:
Cinc04 (08-17-22), SGB4570 (09-21-23)
Old 08-17-22, 02:54 PM
DshngDaryl
DshngDaryl's Avatar
Paul
Nope, my BMW & Mercedes used Hydraulic pumps and I hate them. I much prefer the Motors the SC uses. When the hydraulics go, you get fluid all over.
I really liked the manual roofs for the Corvette and Miata. But at some point someone said at the corvette factory that no one is going to pay a $80K for a top they need to put up manually.
Old 08-17-22, 08:03 PM
GmanSC
GmanSC's Avatar
I wouldn’t buy any car that I have put up the top manually.
Remember the Trans Am with T-top? Just a bad design.
Old 09-21-23, 05:01 AM
SGB4570
SGB4570's Avatar
Hi guys, late to the party here but just the info I was looking for! Thanks.
Old 10-02-23, 07:25 AM
SGB4570
SGB4570's Avatar
So finding this silicone grease is a little difficult! Went to Oriley's, AutoZone and Wally world the other day and nothing. Found some on Amazon however and it should be here today.
EDIT TO ADD: This is the grease I got for it, better on the plastic gears.
Drabek
09-12-22 08:11 AM
scdroptop
11-06-12 02:42 AM
LexLaw
11-17-08 08:13 PM
mdh95070
03-10-06 08:17 PM
iWashDishes
03-16-01 05:12 AM
Quick Reply: Roof folding in SC
