More mods: I cannot stop
Now that I have my car repaired after accident, dreaming of other mods. The only mod I can think of are high flow direct fit cats.
Other than that, not sure if there is anything else left. Don't plan to do the figs 30mm front sway bar because I heard it degrades ride, and not doing nitrous for obvious reasons and not supercharging to to cost and risk. Also do not want to change differential to supra mk4 due to complexity, as well as cost.
Any ideas are welcomed! She is already a monster with current mods and rebuilt engine, but more is always better than less when it comes to sc430 mods :-)
LexBrett, does this mean that all is fixed and working well now?
Yes the major issues are now fixed, had the timing adjusted and now runs as good as ever. Just a couple loose ends; lights around gear shift out, nav door may be off tracks, and abs sensors may need to be cleaned or replaced. Close enough to 100 percent where I can again dream of mods..
That's great LexBrett. Congratulations. You had a long rough road patch, I'm glad you finally made it through.
In fact, when I was test driving other cars that were rated with MUCH higher power, my current set up is actually much faster. Really do need to do a dyno!!!
RMMGS4
97
09-23-06 03:39 PM
