2UR-GSE for sc430?
Old 09-23-14, 06:26 PM
toffee123
toffee123's Avatar
Default 2UR-GSE for sc430?
This is purely fantasy, has anyone tried putting a 2UR-GSE in a SC430 to make it a SC500? According to wiki 2UR-GSE:
The 2UR-GSE is a 5.0 liter (4969 cc) engine and powers the Lexus IS-F, and recently, the new RC-F. It has D4-S gasoline direct injection, Dual VVT-i, and VVT-iE on the intake cam. Bore of 94 mm and stroke of 89.5 mm, it will produce 422 PS (310 kW; 416 hp) at 6,600 rpm and 51.5 kg·m (505 N·m; 373 lb·ft) at 5,200 rpm. in the RC-F, this engine will produce 477 PS (351 kW; 470 hp) and 56.1 kg·m (550 N·m; 406 lb·ft) The 2UR-GSE is an all-alloy quad-cam, 32-valve with high-flow cylinder heads, dual VVT-I with electric VVT-iE inlet camshaft actuation, titanium inlet valves, high-lift camshafts, dual D-4S fuel injection, dual intake air system, tuned length surge tank and stainless steel dual exhaust system. Applications:
2008-Present Lexus IS-F
2014-Present Lexus RC-F
http://upload.wikimedia.org/wikipedi...GSE_Engine.JPG
This engine is 416hp/373lb.ft) showroom stock, not sure if it is any heavier than our stock engine. Perhaps somewhat bigger?
Old 09-23-14, 08:05 PM
ShawnOk
ShawnOk's Avatar
Hmm never heard of the sc500.. but some search did reveal this... http://www.toyota-4runner.org/off-to...500-supra.html. Hmm I also liked the sketches here [but no drop top ]... http://www.toyota-4runner.org/off-to...500-supra.html. Wonder what happened as it was set for 2005?
Old 09-23-14, 08:14 PM
toffee123
toffee123's Avatar
2UR-GSE - 5.0 litre (Bore: 94 mm and stroke: 89.5 mm)
3UZ-FE - 4.3 litre (Bore: 91 mm and stroke: 82.5 mm )
One the 5.0litre would be wider and taller. but shouldn't by much. No information about the weight of these two engines.
Old 09-23-14, 11:48 PM
Black31385
Black31385's Avatar
There is a guy on YouTube that is putting in a 5.7 liter tundra motor in the sc430
Old 09-24-14, 10:46 AM
Harold57
Harold57's Avatar
He has posted here on this forum in the past also.
Old 09-25-14, 11:13 AM
toffee123
toffee123's Avatar
I just communicated with him. It wasn't an easy job, he had to bank the inner strut towers to clear the head. So overall UR engine for SC is a bad idea.
MootGobs
11-02-18 04:30 PM
BumpMaster
IS F (2008-2014)
25
11-18-14 06:32 AM
bacardi
03-23-12 07:11 AM
Quick Reply: 2UR-GSE for sc430?
