sc430 clock resets every time you turn the car off
Old 06-23-11, 10:15 AM
matchflick
matchflick's Avatar
Question sc430 clock resets every time you turn the car off
So everything in my car has no memory issues but my clock always says 1:00
when I start the car....
I have tried another control unit (the climate control, nav screen, etc buttons) where the clock is located to see if I had a bad unit and it still did the same thing.
I have a brand new battery from Lexus and everything else in the car seems to be fine....this was an issue before I bought the new battery.
Any suggestions?
Old 06-23-11, 10:22 AM
mandyfig
mandyfig's Avatar
Very weird. Keep on asking.
Old 06-23-11, 05:05 PM
Harold57
Harold57's Avatar
Sounds like it may have a bad power connection or a loose ground.
Old 06-27-11, 11:42 AM
FrancoP
FrancoP's Avatar
Default Mine has a similar problem...
My clock won't keep time. It doesn't revert back to 1:00, but simply stays at the time it's at when the car is turned off. Everything else seems ok (though we're new owners). I know some circuit boards have a "watch" type battery in them. I'm wondering if there are any such auxiliary batteries in use here.
Thanks.
Old 06-27-11, 11:57 AM
redliner8
redliner8's Avatar
maybe unplug the battery from the car for 30 min, then reconnect.
Is 1:00 a significant time in your life? maybe its trying to tell you something lol
Old 04-06-14, 09:36 AM
scyul
scyul's Avatar
After installing new radio, I have the same problem... Shows 1:00 everytime I start the car + when I turn off the car, the clock goes off (should stay on... Right?). I check the fuse list but none says "clock" or "clock memory" any suggestions?
It's like the climate control is not getting the constant 12v... Anybody has the wiring diagram of climate control unit?
Thanks!
Old 04-06-14, 10:18 AM
DarthSid
DarthSid's Avatar
How did you connect the red and yellow wires from your radio?
Old 04-06-14, 10:20 AM
DarthSid
DarthSid's Avatar
May bad. Have you removed the climate control device and/ or checked the connection on the AC control unit?
Old 04-06-14, 12:49 PM
scyul
scyul's Avatar
I'm sure about the radio connections. It keeps the memory just fine.
The clock is the only issue. Not a big deal but still... It's bizarre... Must be a blown fuse somewhere.
Old 04-06-14, 12:50 PM
scyul
scyul's Avatar
The tree connectors are back where they belong... Strange...
Old 04-06-14, 01:22 PM
DarthSid
DarthSid's Avatar
Here are the wiring diagrams for the clock.
Attached Thumbnails sc430 clock resets every time you turn the car off-image.jpg
Old 04-06-14, 01:23 PM
DarthSid
DarthSid's Avatar
Next diagram.
Old 04-06-14, 01:25 PM
DarthSid
DarthSid's Avatar
The wire harness labeled A10 has the white/red wire for positive voltage and the white//black wire for ground or negative.
Old 04-06-14, 05:08 PM
scyul
scyul's Avatar
Great info DarthSid! I will check it out tomorrow. Many thanks!
Old 04-06-14, 05:16 PM
DarthSid
DarthSid's Avatar
I purchased the Electrical Wiring Diagram book last November when I was working on my instrument cluster and its come in very handy. Happy to help and best of luck.
Quick Reply: sc430 clock resets every time you turn the car off
