25mm Spacers
Old 11-26-03, 08:57 AM
dsimo
dsimo's Avatar
Default 25mm Spacers
I just posted some pics in the Gallery of my SC with rear H&R 25mm spacers installed and Pilot A/Ss, size 245/45-18.
Old 11-26-03, 11:59 AM
Doc C
Doc C's Avatar
Looks great!!! Congrats!!!!
Doc C
Old 11-26-03, 02:05 PM
LexPro
LexPro's Avatar
Nice!
Old 12-08-03, 07:46 PM
oldhotrod
oldhotrod's Avatar
Question 25 mm spacers
Hi guys--new to forum, any information as to sourcing for 25 mm spacers would be greatly appreciated!!
Old 12-09-03, 05:42 AM
Letsride
Letsride's Avatar
Do a search for H & R spacers. You'll find some good info as well as some sources for purchasing them.
Old 12-09-03, 06:23 AM
dsimo
dsimo's Avatar
Options Auto Salon (www.optauto.com) seemed to have the best pricing but unfortunately didn't have them in stock when I was trying to order them. I purchased mine from ECS Tuning (www.ecstuning.com). Both companies seemed to offer good customer service.
Old 09-18-07, 09:06 PM
BNR34
BNR34's Avatar
Hi dsimo,
I just saw the pics of your car with the wheel spacers:
https://www.clublexus.com/gallery/da...acers-rear.JPG
I got a few questions:
Is the 25mm spacer on all 4 wheels?
Is the car lower at all, or is it stock height?
I absolutely loves how your car look, I want to do the same. As I get older, I prefer the OEM look more then aftermarket looks, so I want to keep the OEM wheels, just get wider tires with taller sidewall, then get spacer to push the wheels out to be flush with the fender. Which is exactly what you did, it looks perfect!
Thanks in advance!!
Old 09-18-07, 09:44 PM
SC430Sam
SC430Sam's Avatar
Here is a link that works (takes one of the http's out.
http://www.clublexus.com/gallery/dat...acers-rear.JPG
Old 09-19-07, 08:56 AM
BNR34
BNR34's Avatar
Thank you Sam
Old 09-19-07, 07:16 PM
MrSkinny
MrSkinny's Avatar
I actually have some spacers for sale. brand new hub centric in 20 mm and 25mm send me a pm if you guys are interested
Old 09-20-07, 07:43 AM
dsimo
dsimo's Avatar
Actually, I recommend 15-20mm up front and 25mm in the rear. I have 25mm all around but I think the fronts are just a little too far out (I'm not sure I had the front spacers installed at the point of that photo). With the 25mm in front I get a rare rubbing of the tire against the inner fender when I hit a large dip at a highway speeds.
I'm using the 25mm up front only for convenience because they simply bolt-on. The H&R spacers that are less than 25mm require replacing the wheel bolts with longer bolts are that are supplied with the H&R spacers. I never seriously investigated replacing the bolts so I don't know what effort/cost it would incur.
I've had mine installed for years now without problem. I have the Lexus dealer check them every 5k miles at each service.
And of course I recommend using only a high quality spacer like the ones from H&R.
Old 09-20-07, 07:54 AM
dsimo
dsimo's Avatar
...and, no, it's not lowered or modified in any other way. BTW, I still get TONS of compliments on the car. I don't know why our SC wasn't designed with a wider track.
Old 09-20-07, 12:32 PM
BNR34
BNR34's Avatar
dsimo,
Thank you very much for answering all of my questions, I really appreciate it
Again, your car look perfect in my opinion.
Sceptre
10-22-09 04:37 PM
RI-Lex
01-12-09 09:54 AM
SloGS400
11-11-07 11:27 AM
gs4to4
Suspension and Brakes
48
06-07-02 03:49 AM
Quick Reply: 25mm Spacers
