IL Need to sell my Project with Built Engine
I'm selling my Lexus SC400 shell with a Built 2JZ-GTE single turbo engine. Asking $10,000 OBO
(Pictures to come when I can get to my PC and upload them)
It is a fresh build and has never been run. I'm selling the project because I've recently been married and now purchased a house. I will be going back to school and won't have the time or funds to finish the last few steps of my build.
I'm currently in southern IL and would prefer local pick-up, but I will be willing to help arrange a freight pickup of some sort if need be.
I have many recipes and pictures of the work in progress I can share if need be. The engine is currently assembled and bolted in the engine bay. I do not wish to part it out at the moment. As I have more that 20k into this project with a majority of it being for the engine, the price is firm.
The Shell is clean an modified ready for a manual transmission. Has needs head lights reassembled or replaced and needs hood. Not pictured is '92 front bumper with OEM lip. There are a few nicks in the paint that any car this old will have, but there is no rust. The car has most of the original tan interior minus the front seats.
Also included is a black interior
Black is missing the top section of dash, passenger door panels, seats, arm rest pad.
I will be piling it full of all odds/ends/parts accumulated for this project to be included with the car.
Here's most of the mods and work done to the engine. I'm pretty sure I've got everything, but I there is always a possibility I forgot something, Email me with questions.
Engine Machine Work
Block media blasted
Head/windage tray/etc hot tanked
Block bored and honed .020 over
Crank polished
Cams polished
Rotating assembly Balanced
Head mild port and polish
3 angle valve job
Valve seats cut and lapped
Valves shimmed and backlash set
Head Decked
Block Decked
Engine Parts (all re-used stock parts mesured and checked)
New ACL Race rod/main/thrust bearings
< 100 miles CP Forged pistons with new rings (ring gap set for large turbo)
New ARP Main studs
ARP Head studs
New Genuine Toyota GTE MLS head gasket
Master engine gasket set
BC Titanium Valve springs and retainers
New BC adjustable cam gears
New GTE Oil pump
New GTE Water pump
New Megan Racing motor mounts.
Titan Motorsports billet steel timing belt tensioner with new pulley
New Gates racing blue timing belt
New Billet water pump, power steering, and Alt pulleys
New lower timing cover plastics
New ATI Fluidampr crank pulley
New accessory belt tensioner
Greddy style intake manifold 100% tig weld to lower runners
80mm Throttle body
900cc injectors with top feed fuel rail
New NGK spark plugs
Re-manufactured GTE coils + GTE ignitor
EGR delete
New twin scroll stainless steel turbo manifold (Braced)
New Borg Warner S366 turbo
Drive-train
Spec Twin disk p-trim kit
Wilwood Clutch master and hydro slave cylinder
R154 trans
Trans support cross-member
New bellhousing
Tien HA coils (poor shape)
Stock suspension on car
Engine Machine Work
Block media blasted
Crank polished
Cams polished
3 angle valve job
Head Decked
Block Decked
New ARP Main studs
ARP Head studs
New GTE Oil pump
New GTE Water pump
80mm Throttle body
New NGK spark plugs
EGR delete
Drive-train
R154 trans
New bellhousing
moskiter
11-05-09 02:30 PM
