Master cylinder
Old 06-01-15, 08:36 PM
theazz
theazz's Avatar
Default Master cylinder
Changing out my recent leaking master cylinder on my 03 SC430. Anything special I need to know
Theazz
Old 06-02-15, 12:17 PM
TXFM
TXFM's Avatar
As I posted a little earlier on another MC leaking problem:
You might want to check the brake solenoid valve rubber o-ring. Mine was leaking, but Lexus doesn't sell the o-ring by itself. It's better to take the old o-ring to a parts house and let them size it to one they have in stock. My local Dallas repair shop did this for me, but I don't know the size they found that worked.
Fyi, my SC430 has around 184K miles on it.
Old 06-11-15, 05:12 PM
theazz
theazz's Avatar
So I removed the leaking master cylinder. Pretty straight forward, installed the used one connected everything up and NO BRAKES the pedal goes to the floor. Figuring I was now in over my head I called the Toyota dealer close by and asked them how much to flush the old fluid and install new fluid and of course bleed the system which I knew I was going to have to do anyway.. They said $149 for that service. So I took the car
(using the parking brake as my only way to stop) to the dealer. Of course after looking over everything they said it won't be that simple since there is air in the master cylinder as well as the lines and the all computer settings would have to be reset. I've used these guys before and their very up front explaining in detail what they needed to do. So the total was $349 instead of the $149 but it appears everything is working as it should. I bring this up only for those going to go through this that there's more to it than changing out the unit.
theazz
Old 06-12-15, 02:22 AM
Bgw70
Bgw70's Avatar
Azz, I really thought you knew the brakes would need to be bled and certainly would have warned you if I thought you did not know this!!!
I too had to bleed the master cylinder before I bled the brake system.
Glad you have the job completed and your SC is back on the road!
theazz
Old 06-12-15, 04:08 AM
theazz
theazz's Avatar
Well I did know the brakes had to be bled but didn't' know about the reset of all the functions. Now let's hope NO more leaks.
Thanks for your comments
Theazz
theazz
02-01-17 10:36 PM
Lukas99GS
06-13-14 07:02 AM
M.Rad.
Suspension and Brakes
05-29-12 04:30 AM
gilbeej
11-29-10 02:32 PM
porn-adkt
05-27-10 11:01 AM
Quick Reply: Master cylinder
