Winter Advice
Old 11-13-13, 08:53 AM
jomo3640
jomo3640's Avatar
I am in the same situation - for several years I was able to keep the SC out of chicago winters, but I now need to drive it daily - Does anyone have a recommendation/supplier for snow tires??
Old 11-13-13, 07:40 PM
OBP
OBP's Avatar
I have used an old set of Bridgestone Blizzaks on my SC for a few years. No problems to report. But it's not like I specially went driving in a blizzard or anything like that. Was fine in 2 inches accumulation.
I also used Hankook Winter Icept on another car - tough to balance properly but once done, rock solid in the snow.
Old 11-13-13, 10:13 PM
akdash1
akdash1's Avatar
With my SC430, the colder it is, the better the fuel mileage I get. If it's steadily below -10 Celsius, I'll average over 21 mpg in the city. My winter tires are mounted on very lightweight 17" x 7" rims which contributes to this.
It's usually better to have narrower treads when driving through accumulated snow, but this comes at a cost of reduced traction in other conditions. Any wider than 245 mm would probably be pushing it. I have 225's mounted on my wheels, I wouldn't recommend going below that either..
Old 11-14-13, 10:59 AM
OBP
OBP's Avatar
Yes agree with Akdash. My winter set for the SC is 225 55 16.
Old 11-17-13, 09:51 PM
akdash1
akdash1's Avatar
Another couple of tips. If your running winter tires, you need to keep the pressure much lower than all seasons or summer tires. I have mine at 35 psi, which is a bit high, but it also varies from tire to tire. Make sure you measure the pressure when the wheels are cold.
You can also let out a couple psi's from all-seasons to get more grip.
If you don't want to waste trunk space on a sand bag, you can fit one under the mat in the slot for the spare tire. I put one which I believe was 18 kg's (might have been 16 though) and it was a perfect fit. Another option is, if you have room behind the front seats, you could put them in between the front and rear seats. Personally, my seat is more or less touching the back seat, so it's not really an option for me. My head is also only a couple of inches from the roof when I sit up straight. I actually hit my head on it a quite a few times before I got adjustable coilovers. The really weird part is that I'm only 5'8. Anyway...
ArmyofOne
Maintenance
02-25-16 07:02 PM
ArmyofOne
Pacific
33
04-09-10 05:41 AM
Dima87
Chicago Lexus Club
03-05-06 01:16 PM
dinh626
Maintenance
10-06-04 02:33 AM
BuyERTS
11-06-03 03:55 PM
Quick Reply: Winter Advice
