real time help - castor correction
Old 05-20-13, 11:14 AM
fj40ih8mud
fj40ih8mud's Avatar
Default real time help - castor correction
So, if you recall, my tires new to me sc430 had some bad tire wear on the inside. Put all new shoes on her and took her to get aligned. It was close to spec, just barely off, but they could not adjust it. I am thinking the only solution is to add these...
http://www.spcalignment.com/componen...AFrom&to=USATo
anyone have experience with these? Good brand? Anything else I should do when I replace these?
Also, is there a good place to order these? looks like they are on amazon for $350.00.
Thanks,
Old 05-20-13, 02:36 PM
mrblister
mrblister's Avatar
The unit says its for the GS model. Are you sure it will fit sc430?
Old 05-21-13, 07:23 AM
fj40ih8mud
fj40ih8mud's Avatar
Yes, it fits, GS and SC share this part. Confirmed at vendor site and on this site.
I ordered from Amazon, will report how it works out.
Old 05-21-13, 11:33 AM
bacardi11
bacardi11's Avatar
let us know how they work out.
Old 05-21-13, 03:36 PM
Bon
Bon's Avatar
Thanks,
Cheaper than an OEM replacements at that price: About 1/2. That's all I know.
Old 05-27-13, 03:29 PM
V300Graham
V300Graham's Avatar
When your caster is marginal or slightly off, you need new tension arms or bushings in the tension arms.
By all means get the adjustable caster wishbones, but you will mask the pre-existing problem with the caster arm bushing, which by the way generally suffers from a hidden failure and is only testable properly off the car. ANY cracks in this bushing means it's toast as far as I can see.
The Lexus GS300 on CL men are haunted by this problem for a long time, and my old Twin Turbo Lexus GS300 (JDM Aristo) had it too.
Old 05-28-13, 09:01 AM
fj40ih8mud
fj40ih8mud's Avatar
Put them in over the weekend. Went in real easy. 45 minutes total. At alignment shop now.
Old 05-29-13, 02:53 PM
V300Graham
V300Graham's Avatar
How have they settled in. Is the car cured, or mostly cured ?
Old 05-29-13, 03:57 PM
fj40ih8mud
fj40ih8mud's Avatar
Took them about 4 hours to get the car aligned, but it drives awesome, better than ever. Got the camber to -1.1, where factory spec is -1 to -2.
The shop complained a little of how long it took, but did complement that everything was adjustable now, so before when they would say that "it was maxed out" or "as close as we could get it", this time they could make it perfect.
Old 06-04-13, 02:44 PM
V300Graham
V300Graham's Avatar
By the way to assist people looking solutions to other castor issues. the ACT 537 replacement bushing DOES fit the Lexus SC 430.
Old 06-09-13, 05:42 PM
I-FORCE
I-FORCE's Avatar
i got these on with my coilovers.. Served the purpose and are excellent quality.. Just wondering how much they'd last with the ball joint with so much pressure on it
Old 07-02-13, 06:49 AM
fj40ih8mud
fj40ih8mud's Avatar
Default comparison pic of the new upper a arm.
Here are pics.
Attached Thumbnails real time help - castor correction-img_7347.jpg   real time help - castor correction-img_7348.jpg   real time help - castor correction-img_7349.jpg   real time help - castor correction-img_7351.jpg
Old 07-02-13, 08:07 AM
mandyfig
mandyfig's Avatar
So these are fro the fronts right? How about the back?
Old 07-02-13, 09:51 AM
fj40ih8mud
fj40ih8mud's Avatar
I only had to do the fronts. I don't recall if they had them for the rear. You can check their website.
Old 07-02-13, 02:34 PM
iolmaster
iolmaster's Avatar
I was told by Lexus that castor is not adjustable on the SC and it has nothing at all to do with tire wear. In your title, did you mean camber not caster?
Quick Reply: real time help - castor correction
