change brake light
change brake light
I'm new to the club and cannot find a way to get to the passenger side brake light to change it. Can anyone help? 2004 SC 430
Welcome to CL
That's an easy one, open the trunk and look at the lamp. You will see a small round cap with a slot under it in the black surround. Prise the cover off with a flat screwdriver, undo the single screw under it and pull the whole lamp backwards. May take a bit of pulling and wiggling, but it will come off. All the bulbs are then accessible.
Hope that helps, post some pics of your car when you can.
Best regards
Steve
There are lots o0f threads dealing with the tails. Steve's right.
Here's one:
https://www.clublexus.com/forums/sc-...cs-inside.html
Good luck.
Here's one:
Good luck.
