Lexus Logo Puddle Lights & Door Speaker DIY
Old 04-20-13, 01:17 PM
mandyfig
mandyfig's Avatar
Default Lexus Logo Puddle Lights & Door Speaker DIY
My right side door speaker was starting to go south so I knew I had to replace it. I still had 1 set since I replaced the DR side months ago. So since I was tearing down the Panel, might as well do the Puddle Light DIY as well.
Here are some teaser pics. I took my time, am happy with the results. For little money and a ton of hard work, results are so gratifying at least for me.
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-dr-1-.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-dr-2-.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-sp.jpg
Old 04-20-13, 01:18 PM
mandyfig
mandyfig's Avatar
Complete DIY coming...now off to the party!
Old 04-21-13, 09:40 AM
mandyfig
mandyfig's Avatar
Starting with the Speaker Replacement:
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-1panel-off.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-2frame-ready.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-3spe-sony.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-4mounted-back.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-5mounted-frt.jpg
Old 04-21-13, 09:42 AM
mandyfig
mandyfig's Avatar
Final pics for the speaker replacement, bought these from Crutchfield, ither than the 2 posts that needed cutting, everything was a direct fit.
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-6assy.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-7installed.jpg
Old 04-21-13, 12:53 PM
mandyfig
mandyfig's Avatar
Now it is time for the Door Puddle Light Install:
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-1-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-2-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-3-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-4-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-5-puddle.jpg
Old 04-21-13, 12:54 PM
mrblister
mrblister's Avatar
Default Puddle Projectors
Mandyfig
Very Nice write up
I drilled my door panels at the bottom enclosed some pics.. I installed a male female connector wired to the courtesy light wires so if you have to remove panel in the future you can unplug the projector.
The finished projector in the panel is flush to the bottom and when door is closed lens is protected from water and dirt.
Nice mrblister. I wanted to be near the courtesy light.
Please take a picture of your light in action.
I will take a picture and post. They really show up well at night not so much in daylight. I also bought the blue versions but It was not as bright as the white so I installed the white ones.
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-dsc02411resize.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-dsc02412resize.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-dsc02415resize.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-dsc02416resize.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-dsc02413resize.jpg
mandyfig
mandyfig's Avatar
Moving along...just take your time...
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-6-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-7-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-8-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-9-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-10-puddle.jpg
Old 04-21-13, 12:56 PM
mandyfig
mandyfig's Avatar
Final stages of the door puddle Lexus Logo...
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-11puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-12-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-13-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-14-puddle.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-15-puddle.jpg
Old 04-21-13, 01:01 PM
mrblister
mrblister's Avatar
Mandyfig
How did you wire your projector to the courtesy lights. Did you use a removable connector ? Sorry you uploaded before I saw it
Old 04-21-13, 01:20 PM
mandyfig
mandyfig's Avatar
Going to the rear puddle light:
Tip
You will need to bore holes on the plastic tray and the PANEL. Bon just bore the hole through and he hit the tray and the panel. In fact he did not even disassemble the panels. Hence he had some time to snake the wiring. taking out the panels wan not hard and it took 5 minutes.
The rear is straightforward. Just take time and always make sure your connections are good and secure. The pitfall here is the wires used are so flimsy. Other that that the happiness factor is high. It shuts off after a few minutes which is good.
Here are the pics:
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-1rear.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-2rear.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-3rear.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-4rear.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-5rear.jpg
Old 04-21-13, 01:22 PM
mandyfig
mandyfig's Avatar
While the panels are torn down vacuum away...
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-6rear.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-7rearjpg.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-8rear.jpg   Lexus Logo Puddle Lights & Door Speaker DIY-10rear.jpg
Old 04-21-13, 02:52 PM
mandyfig
mandyfig's Avatar
This is a set of the Puddle light with the plain Lexus Logo. The hole saw is perfect in size.
Attached Thumbnails Lexus Logo Puddle Lights & Door Speaker DIY-lex-logo-puddle.jpg
Old 04-21-13, 02:59 PM
iolmaster
iolmaster's Avatar
I thought they had to be 8 ohm speakers??
Old 04-21-13, 03:14 PM
mandyfig
mandyfig's Avatar
Not really. Lots of discussions on the ohms. Works for me.
Old 04-21-13, 04:28 PM
hlthlnk
hlthlnk's Avatar
Great work! Thank you for all the detailed info.
Quick Reply: Lexus Logo Puddle Lights & Door Speaker DIY
