Do 2GS sway bar fit on SC430?
Old 01-25-12, 02:59 PM
BNR34
BNR34's Avatar
Default Do 2GS sway bar fit on SC430?
Do anyone know if 2GS and SC430 sway bars are interchangeable?
Maybe just the front? They looks pretty much the same to me.
Thank you.
Old 01-25-12, 03:21 PM
bacardi
bacardi's Avatar
your answer is no.
Old 01-25-12, 03:44 PM
BNR34
BNR34's Avatar
Thank you
Old 01-25-12, 03:56 PM
bacardi
bacardi's Avatar
if it would work and it was heaver then the 430sc you have heard about it.
Old 01-25-12, 04:06 PM
BNR34
BNR34's Avatar
I agreed.
Someone did mention it before. I believe the 2 chassis is almost identical, as seen by their interchangeable shocks / coilovers. I think their sway bars are interchangeable, but they are at different rate because the SC is heavier at 3850 lbs and the 2GS is only about 3650 lbs. But then is only 200 lbs differences. People have reported that 2GS coilover on the 2SC drive great.
I am going to dig deeper, I actually got both a 2GS and a 2SC at home, will look at the actual thing carefully.
Old 01-25-12, 09:55 PM
bacardi
bacardi's Avatar
the dampers are worth looking in for sure.
Old 01-26-12, 09:12 AM
BNR34
BNR34's Avatar
Oh yes, damper is single handedly the most important thing on a car, because you feel that in every moment of the drive.
empera
01-12-16 06:57 AM
ALBINO
10-15-13 01:17 AM
Peter_Klim
11-13-11 04:40 PM
Peter_Klim
09-05-10 04:50 PM
DoubleWhoosh
03-09-04 11:08 PM
Quick Reply: Do 2GS sway bar fit on SC430?
