Help: Mechanic can't find O2 connector inside car
Old 12-21-11, 06:34 AM
airmaui
airmaui's Avatar
Default Help: Mechanic can't find O2 connector inside car
Hello,
My mechanic is changing the downstream O2 sensor on the driver side. He took apart the shifter console but can't find the O2 connector. Could someone please tell me where to find or where to access the connector? Thanks very much.
Old 12-21-11, 11:37 AM
VVTiBob
VVTiBob's Avatar
Unlike other Lexus models the sensor connector is outside cabin. But may not be noticeable if a previous owner used a universal one and cut off the connector. Surprised your mechanic would look for that end first....
Old 12-21-11, 12:41 PM
airmaui
airmaui's Avatar
Default Oxygen sensor connector
I'm pretty sure the upstream connector is inside the cabin because the original and the replacement sensor have a large "grommet seal" to attach to the body. The defective sensor is the original and doesn't have an external connector.
Old 12-21-11, 02:20 PM
VVTiBob
VVTiBob's Avatar
bank 1 sensor 1 is in the engine compartment. Comes off the exhaust manifold just before the flange. Does he have the correct part?
Attached Thumbnails Help: Mechanic can't find O2 connector inside car-bank1-sen1.png
Old 12-22-11, 05:06 AM
airmaui
airmaui's Avatar
Default O2 sensor
I'm probably confusing upstream from downstream. It's the driver side sensor whose wire goes through the floorboard and into the cabin.
Old 01-26-12, 05:56 AM
S1 Soarer
S1 Soarer's Avatar
I got MIL P0135. Does anyone have Lexus part # for bank 1 sensor 1 driver side? Found Lexus part # for bank 2 sensor 1 #89465-50130 and Denso oem # 234-4630? Is it the same sensor? Thx in advance.
Old 01-26-12, 07:31 AM
VVTiBob
VVTiBob's Avatar
Lexus part# 89465-50120 bank 1 sensor 1 (upstream driver's side) or Denso part# 243-4138 Denso Catalog Follow the link and enter your car's info for a parts list)
dwlink
RX - 3rd Gen (2010-2015)
10-11-19 04:19 AM
ADENNARD
05-21-13 06:27 AM
sleepyray
IS F (2008-2014)
16
10-10-12 04:07 PM
Blaizze
10-03-08 12:37 AM
Quick Reply: Help: Mechanic can't find O2 connector inside car
