suggestions needed
suggestions needed
Sorry in advance, it's alittle long.
So tonight, I'm driving my 02, and my check engine light start flashing. I'm only a couple miles from the house so I just continue home. I don't notice anything else yet. As I'm turning into my neighborhood, I notice the engine is running rough, kinda like it's not running on all 8. It's not back firing, nothing else. So I park the car and shut it off. I check the all fluids just to make sure the engine wasn't low.
I go in the house, take a deep breath and look up in the manual for a possible cause. It says the electronic throttle control. Ok, so that's a possibility. And in the manual, it says that it COULD fix itself once the car is restarted. So I looked up in the forum here and a couple people said to disconnect the battery for 30 sec or more to reset the system and that might fix it. So I give it and shot and go out, do the battery thing and then start it and the check engine light IS NOT on, but it is still running rough. So I take it around the block, ya never know right? But nothing changes, so I go back to the house, cut it off. I click over the ignition again, start it again and the check engine light is off again.
Any thoughts, maf dirty, throttle control,,,,anything???
