sc430 clock resets every time you turn the car off
Old 04-07-14, 06:47 AM
kjcole
kjcole's Avatar
I would check the wires for the clock where they enter the connectors and look for one that has pulled free from the connector block. So tug on those wires looking for a loose one. Then check pins on the male connector for the unlikely chance that a pin has folded over or is missing.
Old 04-07-14, 07:13 PM
FLYCT
FLYCT's Avatar
You lost the 12 volts at pin 8 R-W wire.
The clock should display time even with no key in ignition.
Old 04-08-14, 09:54 AM
scyul
scyul's Avatar
Well, couldn't find anything wrong with the connector so, I bypassed the problem by cutting to white/red wire and supplying it with the 12v source from the radio...
Old 04-08-14, 10:01 AM
scyul
scyul's Avatar
Originally Posted by DarthSid
I purchased the Electrical Wiring Diagram book last November when I was working on my instrument cluster and its come in very handy. Happy to help and best of luck.
To DarthSid,
May I ask you an other favour?
Can you tell me wich wire on the climate control has the vehicule speed pulse?
My new head unit tells me it must be connected for accurate navigation calculation...
Thanks!
Old 04-08-14, 01:51 PM
DarthSid
DarthSid's Avatar
SCYUL, please refer to the attachments. The SPD sensor color code wire is White/Red (W-R) on PIN # 4 from the Multi-Display. There is also a junction block and wire harness connector at the bottom of the diagram with the same W-R wires. Refer to file Clock_SC430_SPD1
For the second diagram (Navigation ECU) the W-R wire is located on PIN # 5.
Refer to file Clock_SC430_SPD2
Please let me know if this helps.
File Type: pdf
File Type: pdf
Old 04-08-14, 03:43 PM
DarthSid
DarthSid's Avatar
I also failed to include in the second diagram also refer to Stereo Component Amp PIN # 13 for same W-R wire for SPD sensor.
Old 04-10-14, 06:42 AM
scyul
scyul's Avatar
Thanks for taking the time DarthSid!
Your help is much appriciated!
Old 06-21-19, 01:43 PM
Lavrishevo
Lavrishevo's Avatar
Old thread revival. Ugh, same thing happened to me. After I installed my Bluetooth stereo kit no power to the clock with the car off. Double checked all the connectors and all the wires are connected and feel solid. Tried wiggling the harness nothing.
Old 06-23-19, 06:51 AM
Bgw70
Bgw70's Avatar
See post 11 above
Check for 12vdc on the red and white wire. It is always hot
RKD
05-05-17 07:54 PM
R Z
12-24-14 11:51 AM
sschoolc
07-01-14 05:26 PM
andrewbots
06-24-14 07:37 AM
Quick Reply: sc430 clock resets every time you turn the car off
