Went to the shop to get my heat fixed and the car looks like this 2 days later..
The blend door actuators were broken...
Is there anything I should replace while in there. We are replacing the whole heating unit. I think I may ask him to use the heater core currently in the car because that has only 68K miles on it and the replacement has twice that.
Well, may as well do my swap to mostly black interior now....
This is going to cost me a ton....
Wow.... Never seen one like that....
If your side view mirrors do not work, perfect time to replace the mirror controller ECU.
If your instrument cluster is shot, consider sending it to Tanin and have it repaired/restored to whatever color combo you want.
If the trim around your a/c heater vents are cracked, another opportunity....
Check out the Popformance LXCC digital controller.
I am sure others have a list of suggestions as well.....
All those things are perfect. The car had only 68K miles on it. Cluster is perfect and bright. Mirrors work fine, vents are cool. I did take the dash home to SEM it. I'm going to swap out the carpet, seats and brown plastic trim for black.
If I ever have to pay for this job again. The dash will not be going back in.
