1jz oil pan dented
Old 09-19-14, 02:27 PM
driftsc3
driftsc3's Avatar
Default 1jz oil pan dented
Hey guys I'm working on my 1j swap in to my 93 sc300. I got my motor from JDM Miami the other day and noticed that the oil pan is super dented from shipping. i was wording if i could pound it out of just buy a new one?
Its not bad enough to hit the oil pick up line but its still pretty bad
Attached Thumbnails 1jz oil pan dented-photo-1.jpg   1jz oil pan dented-photo-2.jpg   1jz oil pan dented-photo-3.jpg   1jz oil pan dented-photo-4.jpg
Old 09-19-14, 03:52 PM
INTIMAZY
INTIMAZY's Avatar
Mines worse. Didn't do anything about it. It runs fine. Oil is overrated anyway. As long as your oil pickup is flat and not kinked.
Old 09-19-14, 07:28 PM
driftsc3
driftsc3's Avatar
cool man thanks for the advice. Im trying to pull it a little bit but I guess ill just leave it.
Old 09-20-14, 03:26 PM
INTIMAZY
INTIMAZY's Avatar
I was joking about the oil part. But mines been dented for 3 years already.
Old 09-20-14, 04:58 PM
turbodremz
turbodremz's Avatar
I had an oil pan (not on my SC) that was pretty beat up a few years back. I hammered out the dents, had a few that were almost a crease in the metal so I added a little heat with a butane/propane torch and no issues. But as INTIMAZY stated, it wont hurt much and provided the oil pick up is fine, you just have an ugly oil pan.
Old 09-21-14, 12:12 AM
driftsc3
driftsc3's Avatar
cool ill try using some heat. thanks for the advice.
Old 09-21-14, 12:55 AM
irondonkey
irondonkey's Avatar
bang out that dent.
use a heat gun, apply lots of heat, use a heavy weighted hammer, place a block of wood under pan, and hit it out.
you run the risk of oil starvation with a dent like that. if you drive your car hard, and take turns sharp and fast, all the oil will be run dry from that spot since there are no baffles.
Old 09-25-14, 12:21 PM
sc315
sc315's Avatar
Agreed I dirt dropped my old 240 lost oil pressure banged out the dents good as new. There is an optimal distance of spacing the pickup from the pan however!
stlu1994
NX - 1st Gen (2015-2021)
11-23-15 11:29 AM
TwoForDee1
02-15-14 11:22 AM
Lowskee
03-24-11 03:22 PM
ucfa4
01-01-08 06:01 AM
Boz MoN
03-29-06 02:11 PM
Quick Reply: 1jz oil pan dented
