92 nat bogging issues
Old 08-21-14, 04:20 PM
DS04
DS04's Avatar
Default 92 nat bogging issues
I have a 92 sc, with a recently added turbo kit. Now I'm having some issues. Car revs up fine until 5 grand and then will just sit there and not go past it. Anyone ever have a problem like this? My downpipe didn't have the right 02 bungs so both are disconnected at the moment. Could this be my issue? Or any other ideas. Everything else is stock besides the turbo kit. Wasn't doing this before the install.
Old 08-22-14, 10:22 AM
Kris9884
Kris9884's Avatar
Needs more boost, all of it actually. jk
I would say get everything plugged in like it should be first. No need to go chasing rabbits when the car isn't put together yet.
Old 08-23-14, 08:00 AM
ishootstuf
ishootstuf's Avatar
It's definitely not the O2 sensors. Still stock ECU? Is your coil wire shorting on your turbo intake? Did you use the 4runner distributor cap? What are you using for tuning?
Old 08-25-14, 05:46 PM
Luxor
Luxor's Avatar
Check to see if your MAF sensor is connected or positioned correctly.
Old 08-29-14, 07:32 PM
jaymil31
jaymil31's Avatar
Default re
check you neutral safety switch. If the loop for that switch is close which means engaged the car will not rev above 5k start there. This is the reason for guys going from auto to manual have to engage the neutral park switch to start the car but have to disengage the switch to let the engine rev past 5k I hope this help
GoCarSc300
10-08-07 03:38 PM
MeAn_GrEEn
10-18-04 06:51 PM
Javeman
04-25-03 08:14 AM
sc300wanabT
SC- 1st Gen (1992-2000)
08-02-01 04:51 AM
msray
05-01-01 06:03 PM
Quick Reply: 92 nat bogging issues
