SC- 1st Gen (1992-2000)
Question about Power Steering Air Valve
Old 08-05-14, 02:33 PM
KarateDoc
KarateDoc's Avatar
Question Question about Power Steering Air Valve
I have looked around for the information but haven't found a clear answer regarding the power steering pump and air valve.
http://planetsoarer.com/Power%20steering%20pump.htm
http://www.lexls.com/tutorials/steer...mprebuild.html
I have a 95 SC 400 and the alternator died so it appears as if there was some leaking and fried the alternator. I am going to replace the alternator as well as look at buying or rebuilding my power steering pump.
Every power steering pump I have looked at for the SC 400 does not have a threaded mount for the air valve (see first picture red arrow).
I have read that the LS 400 does have the threaded mount but has a different reservoir (see picture 2).
I know that it has been mentioned that the air valve can be removed and blocked off as well as the vacuum ports.
So my question is:
Should I just use a power steering pump that does not have a threaded port for the air valve and block off the vacuum line or shall I rebuild my pump and install a new air valve and keep the vacuum lines.
Old 08-05-14, 06:13 PM
Dream36
Dream36's Avatar
It's the acv. On my sc400 it was part if the high pressure hose not the pump. It has two vac lines to it. When u find it all u need to do is take the piece to an auto part store and test fit oil drain bolts (one is gonna fit). You just press in a rubber stop the thread the oil drain plug and then vac caps at the IM and intake pipes
I'll search for the exact thread I used
AC37
Performance & Maintenance
10-07-19 08:52 AM
JonnyO78
12-02-18 06:53 AM
theschoens
48
10-28-18 05:29 PM
TMaxxTim
02-09-15 08:16 AM
slickeast
06-18-12 08:18 PM
Quick Reply: Question about Power Steering Air Valve
