SC- 1st Gen (1992-2000)
fog light assembly
Old 03-04-14, 09:48 PM
x2jzsc300x
x2jzsc300x's Avatar
Default fog light assembly
i have a 1996 sc300 just bought 1999 fog assembly can i use my old fog assemply and just use the lamps from the 99 or do i gotta do a whole electrical swap as well ??
Old 03-05-14, 12:20 AM
TheAzn
TheAzn's Avatar
Not the whole eletrical wiring swap. Besides the fog housing, you need the bulb holder and the connectors. Cut the old connectors from your existing harness off, splice on the "new" connectors, plug in, well done.
Old 03-05-14, 01:27 AM
KahnBB6
Forum Moderator
KahnBB6's Avatar
Received 1,250 Likes on 870 Posts
^^^ This. It's easy with a 1995+ SC.
OP, you'll want to order two connectors from Toyota/Lexus: 90980-11156
The electrical probes they require are harder to identify by P/N but if you have made a habit of keeping random old unused Lexus electrical bits you can probably find the right ones to cannibalize. The only thing you'll be missing is the factory rubber seals on the OEM wires/probes.
See this thread: https://www.clublexus.com/forums/sc-...-fogs-diy.html
And this: https://www.clublexus.com/forums/sc-...connector.html
kitsune
IS F (2008-2014)
10-05-16 08:42 AM
wald.sc400
06-17-11 11:11 PM
danger4o5
04-15-08 06:41 AM
Marc-P
02-05-07 09:08 PM
ELEX470
GX - 1st Gen (2003-2009)
13
01-09-06 05:34 PM
Quick Reply: fog light assembly
