SC- 1st Gen (1992-2000)
Door lock doesn't work.
Old 03-04-14, 02:31 AM
LexiiBabe
LexiiBabe's Avatar
Default Door lock doesn't work.
Hi there you guys. My sc400, that I got from my brother, door locks doent work Any one got any pointers on this. Thanks.
Old 03-04-14, 05:56 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Does not lock by key fob or by window switch button or both?
Old 03-04-14, 07:09 AM
LexiiBabe
LexiiBabe's Avatar
Both doesn't work. The window swith is hard to turn to lock but still after turning to lock it does nothing.
Old 03-04-14, 10:21 AM
Vrank
Vrank's Avatar
your brother sold you a lemon
There are little plastic clips that hold the actuator rods in the right place. My guess is they are broken, and putting things in a bind or not making contact at all. Parts are like 2 bucks
Old 03-04-14, 11:00 AM
ArkLaTexSC
ArkLaTexSC's Avatar
Probably out of its slot inside the door panel. Happened with my handle, ended up breaking it and had to get another one.
Old 03-04-14, 12:50 PM
LexiiBabe
LexiiBabe's Avatar
Well it was free as a graduation gift so can't complain. A car is still a car even if it needs a lot of work. And plus I'm in love with this car. Did you guys mean the two little plastic thing with the long wire hooked behind the door handle. Earlier one of those popped out and my passenger door wouldn't open. Popped it back in and door worked again. Is the other one for the locks.
Old 03-04-14, 05:39 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
There are cables that connect to the interior handle to the lock piece itself. It might have broke or fallen off if someone was behind the panel at some point. Lucky. Your brother is awesome!
Old 03-04-14, 06:36 PM
ArkLaTexSC
ArkLaTexSC's Avatar
That it is, yep.
Old 03-05-14, 12:23 PM
LexiiBabe
LexiiBabe's Avatar
Alrighty I will check to see if there's any broken pieces and yea my bro is awesome even though he didnt take care of this beauty. Now she's my beauty to take care of.
Old 03-05-14, 02:31 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
This thread is useless w/o pictures. Did you investigate the clips yet?
Old 03-05-14, 05:54 PM
LexiiBabe
LexiiBabe's Avatar
Not yet today busy eith school and work will post pic tomarrow. And thanks 1jzpwrd for answering the multiple posts I've been putting up lately.
Old 03-05-14, 08:29 PM
turb0g33k
turb0g33k's Avatar
+1 for broken lock cable stuff.
The cable ends (like all of the plastic) are prone to crack. once they are loose, the cable bends instead of pushing the lever in the latch mechanism.
also, does it not lock? unlock? or both? what if you manually flip the lock lever on the handle?
A bad actuator will likely cause a total failure, but only electrically (remote/power lock button) while you can still manually flip the lock. A bad cable can sometime function OK in one direction, but not in the other (lock vs unlock)
Old 03-06-14, 05:11 PM
LexiiBabe
LexiiBabe's Avatar
Well on the passenger side it would go back when I push it to lock. And when I use my key out side it wouldn't budge. Here's the pics the two plastic thing behind the door seems okay. Maybe the wire or something else is wrong.
Attached Thumbnails Door lock doesn't work.-forumrunner_20140306_171125.png   Door lock doesn't work.-forumrunner_20140306_171138.png   Door lock doesn't work.-forumrunner_20140306_171149.png
Old 03-06-14, 08:39 PM
turb0g33k
turb0g33k's Avatar
in the 2nd and 3rd pictures it looks like the sleeve has come undone from the ferrule on the lock cable which might cause your problem. could also be broken at the lock assembly in at the door jamb too.
With the handle out like you have it, try locking and unlocking and see if the cable sleeve shifts. it should not move at all other than flex a little. the black sleeve on the outside of the cable maintains the set distance between the two ends allowing the inner cable to actually do work.
try manipulating the cable as well when your testing to see if it gets easier or harder to lock/unlock.
finally, unclip the lock cable from the handle assembly (white ended cable) and then try the key on the outside of the door to lock unlock. if it now locks/unlocks smoothly, like it should, then the cable is bad.
Old 03-09-14, 03:23 PM
LexiiBabe
LexiiBabe's Avatar
So what do you guys recommend should I change the whole thing. Since this car has 292000 miles already. Is there a diy on changing the lock actuator.
Quick Reply: Door lock doesn't work.
