SC- 1st Gen (1992-2000)
Steering wheel a bit loose
Old 03-01-14, 04:11 PM
AlaskaUSA
AlaskaUSA's Avatar
Default Steering wheel a bit loose
The sc300 steering wheel is a bit loose, like the angle adjuster isn't screwed on tight or something.. It's not so bad but I can wiggle the steering wheel up and down maybe a few millimeters...
Any idea how to tighten it or fix this? Thank you
Old 03-02-14, 05:49 AM
dogwisper
dogwisper's Avatar
It may have been removed in the past and not tightened properly. Relatively easy to find out. I supplied a link to show you where all of the torx heads and bolts are just scroll down the photos until you get to the steering wheel. Disconnect the battery first since the air bag is in there too. I hope this helps with what you are talking about.
https://www.clublexus.com/forums/sc-...highlight=dash
Bucketlist
02-28-15 09:22 AM
is250fsprt
IS - 1st Gen (2001-2005)
01-19-14 11:44 PM
smalldog
10-23-13 05:53 PM
giangy11
06-04-10 12:24 PM
kendre
04-27-06 02:13 PM
Quick Reply: Steering wheel a bit loose
