SC- 1st Gen (1992-2000)
DIY for SC Cluster & Needles
Old 12-12-13, 11:35 AM
  #46
xshurikx
xshurikx's Avatar
Originally Posted by stevechumo
If it read at 250 rpm, then it's probably too heavy. 650 rpm is much better. It'll help if you have an original non-modified needle to compare to. Another thing that I remember is the needles from 92-94 have different polarity from 95 and up.
well i did have a 92 needle to compare it to but after i got my cluster back my speedo was still off. and i never tested it on my tach.
i know its not the car because i tested an unmodified cluster and everything was dead on perfect. i am going to add some counterweights to the back of the needles to balance them better, but this was a step in the right direction.
Old 12-12-13, 11:50 AM
  #47
GTE4Life
GTE4Life's Avatar
Here is my idea for a way to rebuild the needles, maybe some people here have some input.
Get some thin clear plastic rods that can fit in the groove in the back of the needle. They can be acrylic or PVC or whatever is clear and has a nice outside finish. Then grind some small grooves in the backside of the rod, this will scatter the light upward. Then Mask off a little strip on the top of the rod where the it will line up with the front of the needle. Paint the rest with chrome reflective paint. Then connect the end of the rod to a small LED, it can be SMD or whatever will fit on the needle. Coat the connection with clear nail polish to index match the LED to the Rod better.
Now if it works right the light from the LED should travel through the tube (similar to a fiber optic) and get scattered off of the rough bottom and out the non-painted strip and through the needle face.
I believe this is how many "Modern" needles are lit, I think it is not a problem of getting lots of LEDs in there but cleverly guiding the light from a single LED.
DISCLAIMER: I have not done any of this. If I can find a set of spare needles in a junk yard I plan to try.
Old 12-12-13, 04:34 PM
  #48
stevechumo
stevechumo's Avatar
Have you weighed the Lextech's needle? If i remember it right, it's like 1/4 heavier than the stock needle. That's why it's off. Lol.
  #49
xshurikx
xshurikx's Avatar
the idea is good and that is actually what lextech tried to do. they put 1 bulb in the base pointing to the tip and some sort of reflextive thing going through from base to tip. if you look at the review thread there are some pictures there of a cleared out needle but there was reflective stuff before i took it out.
Old 12-12-13, 06:27 PM
  #50
akora12
akora12's Avatar
I'm pumped that someone actually dug into this and is doing some much-needed R&D. You may be working on it now, but what's your solution for the screen lighting of the climate control? I wonder if another led strip like what was used in the cluster would work?
Old 12-13-13, 04:56 AM
  #51
xshurikx
xshurikx's Avatar
Originally Posted by akora12
I'm pumped that someone dug into this and is doing some much-need R&D. You may be working on it now, but what's your solution for the screen lighting of the climate control? I wonder if another led strip like what was used in the cluster would work?
Not sure. I put it in behind the screen and connected to a battery and you can see the leds through the screen. Maybe just resolver some regular bulbs in this case
Old 12-13-13, 05:32 AM
  #52
Bankswood
Bankswood's Avatar
well one month after getting my climate control back from Lextech the bulbs that illuminate the buttons are failing. 2 gone and 2 more flickering. (No surprise).
I'm going to replace them myself this time but before I pull the climate control unit can someone tell me the bulb size and style so I can order them first.
Old 12-13-13, 07:36 AM
  #53
phermes1
phermes1's Avatar
Hey, I have a really dumb/simple question - how easily do the needles come off?
I'm a bit leery of pulling too hard and breaking something. Should they slide right off, is there any resistance, etc.
Old 12-13-13, 09:21 AM
  #54
2jznosht
2jznosht's Avatar
Just pull gently
Old 12-14-13, 02:27 PM
  #55
xshurikx
xshurikx's Avatar
neo-wedge not sure of exact size order 1 of each there are only 3 sizes
Old 05-31-15, 08:18 AM
  #56
xshurikx
xshurikx's Avatar
I am digging up this thread, has anyone done any more DIY can we improve this one in any way. i know people still have there issues. plus i just bought another SC and I might try some back lighting on it if not needles since thankfully they still work well.
Old 05-31-15, 11:59 AM
  #57
TaninAuto
Sponsor
CL Vendor - Starter
TaninAuto's Avatar
Unfortunately I don't think you will be able to just replace them. They modify the inside so heavily it's pretty much non serviceable.
Old 08-19-15, 11:32 AM
  #58
dricacho
dricacho's Avatar
I'm going to be running LED strips around the gauges for backlighting as well, I just need some clarification. Since the controller only has one connection for one LED strip and cutting the strip of 30 LEDs in half makes two strips of 15 LEDs, how will I connect the other strip of LEDs to the same controller? Perhaps I need to run 2 controllers? Also, where did you run the IR receiver for the controller? There isn't much length to the wire for the IR receiver to begin with. Lastly, to power this kit do I just wire the controller directly to a switched 12v source? No need to use the AC adaptor I presume. What would be a good place to tap a switchable power source from?
Next is the LED Strip. I got a 50cm Strip of 30 LED's from Superbright for $16 and a $.59 cent no-solder connector
I cut the strip in half giving me 15 LED's per side (more than enough)
Attached the connector and now we have 2 15 LED strips good to go.
Old 08-30-15, 12:29 PM
  #59
oldManTan
oldManTan's Avatar
i did my needles full with 12 LEDs on the big ones and 8 on the small ones, running in parallel of 4 LED groups, no resistors, been a year and no problems yet. the LEDs can handle a pretty wide range of voltage, pretty sure each PLCC2 LED can handle up to 3.6V, which in a group of 4 is 14.4 which i think is fine.
kingred
02-17-15 10:30 AM
bleedspeed
05-10-11 11:45 PM
A2Rinc
10-02-10 02:14 AM
schwarz
83
12-22-09 02:47 PM
tuan92129
Lighting
09-20-06 01:32 AM
Quick Reply: DIY for SC Cluster & Needles
