SC- 1st Gen (1992-2000)
Wood Trim Refinish Job
Old 05-12-13, 07:11 PM
  #31
jayclapp
jayclapp's Avatar
Looks like you have a few bubbles. Suggest you let the heavy coat of brushed varnish dry really well (maybe two or three days) and then lightly sand those spots away. Then a buff with steel wool or very fine 2000 or 3000 sandpaper lightly. They do a final coat by spraying. Several light coats generally works better than heavy coats.
Old 05-12-13, 08:16 PM
  #32
Ozzzzy
Ozzzzy's Avatar
I was really hoping that the bubbles would work their way out as drying.Oh, well, this is a learning process and I'll take the advice on getting them out.
Old 05-13-13, 11:50 AM
  #33
zneubauer
zneubauer's Avatar
I think I may try this. Lol, Florida sun.
Old 05-13-13, 06:32 PM
  #34
Bksc718
Bksc718's Avatar
i think i may try this !!!!!! nice finish sir
Old 05-13-13, 06:33 PM
  #35
Bksc718
Bksc718's Avatar
niceeeeeeeeeeeeeee
Old 05-14-13, 08:07 PM
  #36
Ozzzzy
Ozzzzy's Avatar
All right. The bubble issue has become a major problem!! I know using a brush is rookie but I can't believe that I can't put on any more coats without bubbles forming all over, bubbles that dry there no less! I've tried cleaning the brush, soaking the brush over night in the finish, thick coats, thin coats, brushing in every possible way but after that first coat goes on, every following coat is filled with bubbles. I'm blaming the brush and getting a different, expensive one tomorrow, after I resand down all the pieces again of course! Damn It!!
Old 05-15-13, 08:01 AM
  #37
jayclapp
jayclapp's Avatar
FORGET THE BRUSH! Just spray it from a can and you won't have any more bubble problems. Simple solution.
Old 05-15-13, 08:28 PM
  #38
Ozzzzy
Ozzzzy's Avatar
OK, Sanded down again, bought a fine, thin nylon brush and have started on coat one AGAIN!
Old 05-15-13, 09:02 PM
  #39
Cleanshots
Cleanshots's Avatar
blow on the surface lightly with a straw if there are bubbles and it makes the bubbles disappear. yea.. i'm serious.
Old 05-16-13, 08:16 AM
  #40
Ozzzzy
Ozzzzy's Avatar
I think I licked it with the new brush, but if I do run into anymore bubbles, I'll try that (alone so no one see me doing it) and post the results.
Old 05-19-13, 10:45 AM
  #41
Ozzzzy
Ozzzzy's Avatar
Here are the finished pieces. I will post pictuers of them in the car when done.
Problem with the website. Can't upload pics at this time. Will try again later.
Old 05-19-13, 11:16 AM
  #42
Ozzzzy
Ozzzzy's Avatar
I won't post until fixed. Sorry for confusion
Old 05-19-13, 04:44 PM
  #43
Ozzzzy
Ozzzzy's Avatar
Here we go.
Old 05-09-14, 12:39 PM
  #44
t2d2
t2d2's Avatar
Thanks for this thread. I replaced my door wood trim pieces with nice ones from some spare door panels, but that just highlights how cloudy the dash ones are! I'll be installing a less cracked center vent piece next week, so that'll be a good time to remove the dash wood trim and try sprucing it up a bit. This thread has provided several good suggestions for how to go about that.
Old 05-09-14, 12:55 PM
  #45
Ozzzzy
Ozzzzy's Avatar
Default Brush
Ignore my posts about using a brush and just go with the spray can.
Quick Reply: Wood Trim Refinish Job
