SC- 1st Gen (1992-2000)
19x11 or 19x10.5
Old 04-14-12, 10:48 AM
scmaluco
scmaluco's Avatar
Default 19x11 or 19x10.5
Alright so IM looking to get some varrstoen lm reps
19x9.5 et 22
19x11 et 25
245/35/19
285/30/19
My rear fenders are shaved alot. And front will be rolled and i have Town coilovers
Will i be able to run the rears without pulling them?
I can change the rear tire to a smaller one. (Suggestions would be great thx)
also might pick up 2 19x10.5 0 off set. (for the rear)
can i run them without pulling the rear fenders??
thanks.
i've been searching and looking at different options on the forum & google too.
Old 04-14-12, 01:15 PM
turbo16lbs
turbo16lbs's Avatar
I'm curious to know too.
Old 04-15-12, 07:41 AM
chnk
chnk's Avatar
no 0 offset, youre gonna have to do a hella roll and pull on your fenders and stretch tires, like a 225 or 245
do 25 offset 19x11, with that tire size youll need a good roll and pull to get them to fit, but much more doable, go with a 275 the slight stretch will help
Old 04-15-12, 06:43 PM
scmaluco
scmaluco's Avatar
Thank you Sir.. finally someone replied . I just don't want to deal with pulling the rears.
will a 265 be too stretched?? got any pics of a 275 on a 19x11 ? thanks. if anyone here is running that please post pics.. thanks again..
Old 04-15-12, 08:15 PM
turbo16lbs
turbo16lbs's Avatar
Did a quick google search and found this:
265 - 30 - 19X11
295 - 30 - 19X11
Old 04-15-12, 08:21 PM
SCott300
SCott300's Avatar
I just posted the same question a couple weeks ago if you want to search for it to see the comments'suggestions that i got.
My title was "19x10.5+30 vs 19x11+25"
I am planning on going with the same brand wheel as you too
Old 04-15-12, 08:24 PM
OG Dada
OG Dada's Avatar
A lot of people do a lot of calculations and trial and errors to get their fitment right. There's also a lot of factors that contribute to this.
Offset would be #1.
Width of wheels.
Ride height.
Fenders.
Tire width and thickness. *Tire brand also varies.
Camber.
And this is the right place for these questions, no need to make a whole new thread when there's a lot of experts checking in here to answer these questions on the daily;
https://www.clublexus.com/forums/sc-...300-sc400.html
Old 04-15-12, 08:42 PM
xrsracer
xrsracer's Avatar
I'm running the 19x9.5 19x10.5 0 offset all the way around. Pulled and rolled both fender with camber. 225/35/19 front and 245/35/19 rear. I'm like a credit card gab going upward.
Old 04-15-12, 09:51 PM
chnk
chnk's Avatar
not a 19x11 but a 19x10.5 with a 265/35/19 and a 26 offset, very similar to your offset. rolled, and slightly pulled fender, no extra negative camber needed, just the natural camber from drop
Old 04-15-12, 11:33 PM
2slow2care
2slow2care's Avatar
I have 285's on a 10.5 +20 18's. All I did was roll my fenders. I don't have any rubbing issues. If that help you any.
Old 04-16-12, 06:14 AM
scmaluco
scmaluco's Avatar
I found your old thread.. thanks and ill try to wait to get some wheels i guess the price i'm paying for those wouldve been 1400 and i can actually get new ones with some decent brand tires for that price. plus the offset that i want. if i end up going with 19s. anyone here regret 19s? i hear it doesn't handle the same as with 18s. =/ . i did some reading on that too already.
Thank you all for the input..
Old 04-16-12, 02:07 PM
xrsracer
xrsracer's Avatar
I just barely switch from my 18" to the 19" now and I don't really feel anything different at all. Unless u go with a hella different smaller size tire or something then maybe.
Old 04-16-12, 03:53 PM
MrCJ305
MrCJ305's Avatar
you'll need to shave and pull the rear at least...front fenders will definitely need roll. I'm running 19x8.5 in the front and I had to roll the fronts
Old 04-16-12, 04:10 PM
scmaluco
scmaluco's Avatar
I want some new wheels pretty bad. not to mention that i need tires too. looks like ill be ordering a new set pretty soon. my money didn't come thru on time so i won't be picking up the 19x11 . anyways the shop recomended +22 all around. so well see. so ill just go with
19x9 & 19x10.5 +22 all around.. rear fender is already shaved..
Old 04-16-12, 05:43 PM
MrCJ305
MrCJ305's Avatar
19x9 in the front & 19x10.5 in the rear will be a nice set up. I'll be getting rid of my 19's soon though & I'm going with 18x9 in the front & 18x10.5 in the rear. make sure you relocate that wire harness in the front when you lower your car because it will eat right through. (Speaking from experience) lol
Quick Reply: 19x11 or 19x10.5
