SC- 1st Gen (1992-2000)
Bad gas mileage!!!
Old 04-19-12, 07:47 PM
guku0701
guku0701's Avatar
thanks for the help.but how did you know it was the o rings?did you smell unburnt gas in the engine bay?
Originally Posted by BlakOnBlak
Hey whats uP. Im no rocket surgean, BUT, if you smell gas then you just might have a gas leak somewhere. Check all your fuel lines to make sure everything is tight. When I first bought my SC I smelled gas too, but it was because the car was missing its charcoal cainister; doesnt make a difference in gas mileage, but took away that gas oder. 92 Sc300 Automatic - 1jzgte swap Good luck. Keep us posted with the outcome of your situation.
Old 04-19-12, 11:00 PM
GS4_Fiend
GS4_Fiend's Avatar
might as well change the o2 sensors. make sure ECT is giving out correct voltage readings.
Old 04-20-12, 03:42 PM
guku0701
guku0701's Avatar
is there anyway i can check if the egr is bad?
Old 04-20-12, 04:37 PM
guku0701
guku0701's Avatar
would deleting affect my gas mileage?like for better or worse?
Old 04-20-12, 09:19 PM
GS4_Fiend
GS4_Fiend's Avatar
unplug the vacuum line that's going to the EGR. If the car smooths out, your EGR is stuck OPEN.
Old 04-21-12, 10:16 AM
Scless
Scless's Avatar
Originally Posted by TechGreek
You used a blow torch to clean an electronic part. Interesting...
EGR Valve hanging open will kill gas mileage.
having a open EGR would cause the vehicle to not start or stall. EGR is only opened on cruising speeds.
Old 04-21-12, 11:13 AM
TechGreek
TechGreek's Avatar
Negative. The EGR Valve is open more than just cruise speeds, things like cold idle etc are all in the FSM.
Old 04-21-12, 11:33 AM
guku0701
guku0701's Avatar
would deleting improve gas mileage?
Old 04-21-12, 11:46 AM
TechGreek
TechGreek's Avatar
Not unless you have an aftermarket ecu.
Your EGR actually cools the combustion temperatures down. The stock ECUs fuel maps compensate for this so when you delete it you'll be running at the wrong af/r
Old 04-21-12, 03:08 PM
guku0701
guku0701's Avatar
thanks for the input...so it wont make my gas mileage worse right/?i mean i get like 10 mpg ritte now lol
Old 04-21-12, 04:01 PM
GS4_Fiend
GS4_Fiend's Avatar
Can you elaborate how does EGR kills gas mileage? EGR is suppose to improve gas mileage. Or you are talking about EGR on at idle?
Old 04-23-12, 05:18 PM
OG Dada
OG Dada's Avatar
Not to thread jack, but is 13 MPG fulltime city driving normal? I got 221mi on fulltank last week. Nothing seems to be wrong with my '95 SC400, no CEL, but one thing I noticed is my exhaust smells a little rich. What should I do first or what should I be looking for first to troubleshoot this? I'm planning on just taking everything apart tomorrow, clean MAFs, clean EGR, change the hoses if needed, clean O2 sensors, inspect spark plugs and wires, inspect distributor... Anything else I'm missing? Thanks in advance.
Old 04-23-12, 05:41 PM
durps
durps's Avatar
If you're driving like a grandpa then NO, not normal for sure. Even for a normal driver, this is bad gas mileage. Unless you're just ripping it after each red light and stuff.
Old 04-23-12, 07:24 PM
OG Dada
OG Dada's Avatar
I used to get 17mpg full time city driving. Then about a month ago, I tried using the ECT/PWR full time city driving, then I get 13mpg for a couple of weeks with it turned on the whole time. Now, it's been a couple of weeks of me NOT using the ECT/PWR and I'm still getting 13mpg full time city driving. Yes, I drive like a granpa if you've seen my thread I said that. I don't even accelerate my SC hard or brake hard. The fuel filter haven't been changed either, and I'm pretty sure ever since the car was new, because there are no signs of the lines being touched by tools of any sort. It's next on my list probably in the next couple of months. Any ideas CL?
Old 04-24-12, 06:44 AM
Revhead95
Revhead95's Avatar
I deleted my EGR and it seems like my gas mileage stayed the same... nothing to write home about tho. still get about 280miles to the tank on my SC300. i believe i have bad 02sensors tho. I had a CEL and TC light on since i got it and i can reset the ECU and it stays off till engine warms up. so I am gonna change my fuel filter and 02 sensors in the near future and see if i get any better mileage.
Quick Reply: Bad gas mileage!!!
