help with Nakamichi lighting
i've been searching the forums and the info is a bit thin. I just replaced all the lighting in my climate control....the 3 twist in's that light the buttons and the 3 soldered in's that light the backlight. The question I have is in the Nakamichi headunit does anyone know if the large buttons are lit in the same way as the climate control with the twist in type? I know the display probably has soldered in bulbs. I'm only interested in changing out the display and large button bulbs to match the climate. Anyone delved into this??
f-n great.....just wanted to change out the large buttons and the screen ( which i figured would be soldered.) isn't really worth it because opening that thing up might cause some problems to surface disturbing all that stuff....
