SC- 1st Gen (1992-2000)
cd player wiring
Old 08-18-11, 08:58 PM
baodalazi
baodalazi's Avatar
Default cd player wiring
i got the 1987 and up toyota wiring that matches with my 92 sc300, and i had a orange wire left on it and all the wires from the cd player are matched up.
any help would be appreciated because the cd player is not turning on.
it fits in the two plugs perfectly and the other two plugs that are not being used are for the cd changer
Old 08-18-11, 09:23 PM
blacksc4
blacksc4's Avatar
as far i knw, there hasnt been a working dash wire kit for the sc besides metra (i think)
but anyway orange should only be for illumination (99%) of the time but that shouldnt effect it turning on or off, check your fuse to make sure it didnt blow as you were putting the wires together, happens quite often, and make sure your cd player is in working condition
Old 08-18-11, 10:24 PM
baodalazi
baodalazi's Avatar
would this one work?
http://www.amazon.com/Metra-Toyota-1...731410&sr=8-14
i bought this one
http://www.amazon.com/SCOSCHE-TA02B-...3731410&sr=8-2
Old 08-19-11, 07:52 AM
blacksc4
blacksc4's Avatar
you can give the metra one a shot, it should work
other people on the forum used 2 wires
Metra 70-8112
Metra 70-7116
that should get it going good
Old 08-19-11, 07:53 AM
blacksc4
blacksc4's Avatar
116 is to be able to use the stock amp (i think) so u should be able to make it by with just using the one from amazon but u wont have the working stock amp
Old 08-20-11, 01:10 PM
baodalazi
baodalazi's Avatar
Default wires
i have the 116 amp one already i just didnt wire it in i used the scosche and it matched everything up.
but still no power i know the sc300 stock radio needs the power button on the bezel to be hooked up and pressed to work.
i tried doing it, but no dice. do i need to splice into the power wire to power up the cd player?
Old 08-20-11, 01:14 PM
baodalazi
baodalazi's Avatar
I also brought the cd player to the local audio shop and it bench tested perfect
Old 08-20-11, 10:53 PM
blacksc4
blacksc4's Avatar
u shouldnt need to splice any wires for it, did you check the fuse? and also idk if the scorshe one works cuz i havnt heard of anyone using it, but the metra should work,
if not ull do what most people had to do and hard wire it,i actually think hard wirirng it slightly a better fix that way you know how good the speaker wire is and its bttr than the stock wiring
Old 08-21-11, 12:22 AM
SC400-PHAE
SC400-PHAE's Avatar
i bought a wire kit that was suppose to work with the stock amp but no go so i just hardwired it wasnt too bad.... that was my first time installing too
Old 08-21-11, 08:13 AM
baodalazi
baodalazi's Avatar
whats hardwiring? is it "raines" thread on running it to the rear trunk wires?
Old 08-21-11, 09:44 AM
blacksc4
blacksc4's Avatar
hardwiring is running everything directly from the head unit itself, headunit to the speaker using your own speaker wire, find a 12v and a ground and n accesory wire just run it all without the stock wiring, theres also a write up to run it from the stock wiring do a search for it
Old 08-21-11, 09:57 AM
blacksc4
blacksc4's Avatar
https://www.clublexus.com/forums/lex...b-working.html
u can do it that way, or the way i did it is run directly from the head unit and i havnt had any problems with it
Tony320
19
11-14-08 11:31 AM
93ls400WD
02-28-07 06:08 PM
Quick Reply: cd player wiring
