SC- 1st Gen (1992-2000)
Half Ass Trans Job
Old 08-01-11, 12:16 PM
Gate
Gate's Avatar
Default Half *** Trans Job
My transmission fluid is well overdue for a change. It's very, very dirty. Shifting is a little rough. I could get a the right amount of trans fluid for about 20 bucks and pull the plug, then just refill it. But those pros do some sort of flush that's apparently of importance, and I'm well aware that filter goes bad eventually but installation for the filter is expensive. I'm sure I'd be much better off just draining and changing the fluid as simple as that and seeing how much that helps all for 20 bucks rather than saving up for a month and driving with the bad fluid that entire time until I can have the full job done. I'd rather take an extra week or two on top of that to get the pro job done in order to at least get some fresh fluid in there in the mean time. Any thoughts on this?
Old 08-01-11, 12:23 PM
Bender25
Bender25's Avatar
The filter and pan gasket combo is only $17 from autozone, and it's really simple to change
Old 08-01-11, 12:29 PM
Gate
Gate's Avatar
That's awesome! Would I also need some kind of moisture/heat resistant liquid drying adhesive to go with the gasket? And how can you tell if you need a flush?
Old 08-01-11, 12:31 PM
horent135
horent135's Avatar
The problem is some SC has sealant or gasket. I have a sealant, so the gasket wouldn't work for me. just FYI.
Old 08-01-11, 12:33 PM
vwynn
vwynn's Avatar
usually if u buy the filter.. (strainer) it will come with a gasket. If not then get the liquid paste gasket makers.
Old 08-01-11, 12:34 PM
Gate
Gate's Avatar
Is it not wise or possible to use a gasket as well as a sealant in unison? Or if it originally had a sealant, it might be harder to remove the pan than compared to just unscrewing it, it sounds like removing one with sealant on it would require some type of dissolving chemical. Is this true?
Old 08-01-11, 12:40 PM
Gate
Gate's Avatar
Okay, sounds easy enough. I suppose I'll have to drain most with the drain plug so it doesn't splash out like a broken pool when I remove the pan, then wipe down and clean all the surfaces for the gasket so there's good contact, clean the pan, change the filter, slap the pan back on, then pour in the new good stuff. All good advice friends!
Old 08-01-11, 12:48 PM
xspsi6
xspsi6's Avatar
SC300 or 400? If 400 then you can use ONLY use Toyota typr t-iv fluid and absolutly nothing else!!
Old 08-01-11, 12:59 PM
Gate
Gate's Avatar
400. Good save, friend! That could have been a close one. Those Autozone guys are cool, but they're salesmen, not mechanics. Okay, I will definitely make sure I get Toyota typer t-iv ONLY!
Old 08-01-11, 01:00 PM
horent135
horent135's Avatar
I think that goes same with 300 too, but I used Toyota tranny fluid to keep it safe.
@Gate, With the sealant after you unscrew all the bolts, just take a flat head and pry it out. Careful not to bend the pan too or you can just buy a new pan.
Old 08-01-11, 01:07 PM
xspsi6
xspsi6's Avatar
Yes you should use the Totota type t-iv in both 300 and 400 which is a step a lot of forum members skip or cheap out on since the bottle of fluid at the local parts store says it can be used which is very un true!
Old 08-01-11, 01:13 PM
Gate
Gate's Avatar
Yeah, Damn those salesmen. I understand people got to make a living, but at the expense of the unwary? Misleading them into traps that expensive to crawl out of (and you will be crawling by the time you get out)? That's not right.
Lucky for me I've got you guys!
paul3991
GX - 1st Gen (2004-2009)
09-10-18 05:44 PM
wsrivers
11-19-17 02:31 PM
dpw2552
03-27-17 02:40 PM
shawnfuzzy
GS - 1st Gen (1993-1997)
05-13-12 10:11 AM
carguy07
RX - 1st Gen (1999-2003)
12
12-09-07 01:15 PM
Quick Reply: Half Ass Trans Job
