SC- 1st Gen (1992-2000)
EGR Valve
Old 05-25-11, 01:58 PM
ALLWiTE2JZ
ALLWiTE2JZ's Avatar
Default EGR Valve
Old 05-25-11, 02:50 PM
MuGGzyx
MuGGzyx's Avatar
it's an easy part to check and clean so no reason NOT to pull it and clean it in case that is the issue.
Old 05-25-11, 05:18 PM
lookEVO
lookEVO's Avatar
I got an an exhaust before i went turbo and i stopped getting egr codes
Old 05-25-11, 11:09 PM
P.R.S.22
P.R.S.22's Avatar
I've had my EGR code on for almost 3 years now coming in June and my idle does not get lower and lower once I turn the car on. If your idle is getting lower and lower the way you say it is, it might be a different problem with the SC. You could always try and check with the EGR valve first and then see if the idle problem goes away.
BHKH
08-03-19 08:31 PM
johnblagg
13
01-03-12 05:28 PM
FAT HEAD
Performance & Maintenance
12-21-09 11:00 AM
svptwobe
Maintenance
06-03-02 08:34 AM
svptwobe
05-30-02 05:54 AM
Quick Reply: EGR Valve
