SC- 1st Gen (1992-2000)
LED upgrades/conversion
Old 04-28-11, 08:05 AM
alfa spade
alfa spade's Avatar
SWWEETT. pretty cool looking
Old 08-25-11, 05:37 PM
Nova
Nova's Avatar
kingphillip, what bulbs did u use for the dome lights, visor lights, trunk compartment, and license plate frame lights. also did u use a DIY or do you have one for the visors. cant visualize if the lens pops right off
also did u change the lower door lights as well?
Old 08-25-11, 05:51 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Originally Posted by Relapser
NO OFFENCE
okay
straight up NO offense
BUUUUUUTTTTT i put an LED bulb in my interior light and i hated it!!! i wanna pull it out n revert back to the normal type ...
..normal filament globes just give off a warm loving light.. the LED however... is just garbage.. unless i replace it with an amber colour?
but right now it's a white LED and it's just such a cold, clinical unforgiving shade of "white"
aside from that everything else looks fantastic.. like dash lights and gearstick lights look great!
just - i cannot stand my interior light personally
https://www.clublexus.com/forums/lig...ymods-com.html
post 8 .... lol. The exact word "clinical".
Old 08-25-11, 05:56 PM
OG Dada
OG Dada's Avatar
I updated the sizes of the bulbs on my first post!
Yeah, it does feel a bit "clinical". But works for me whenever I drop something on the floor or working in my car at my pitch dark parking spot.
Old 08-25-11, 06:12 PM
Nova
Nova's Avatar
did u use the light socket adapter for the dome light?
Old 08-25-11, 06:17 PM
OG Dada
OG Dada's Avatar
Yup, there's really no other application for it if you want it to be bright enough. If I remember it right you have to order what kind of socket you need for an extra $2. I'm not sure.
Old 08-25-11, 06:33 PM
Nova
Nova's Avatar
still not sure i understand what u did with the visors, u used three different bulbs or just 1 of the 3910-x6 festoon bulbs
Old 08-25-11, 06:40 PM
OG Dada
OG Dada's Avatar
When you remove the cover, you'll find a fuse type bulb being held by 2 fork type terminals, upper and lower part where the contact point's are. The bulb I chose is the closest size to it. Although when you try to squeeze it between the terminals it's too fat so it just keeps on popping out. But when you put the cover over it it will keep the festoon bulb in place.
Old 08-25-11, 06:42 PM
Nova
Nova's Avatar
understood, thanks for the info cant wait to order these !
Old 08-25-11, 06:44 PM
cmh
cmh's Avatar
looks good my man...
OG Dada
OG Dada's Avatar
I'm obliged. Good luck!
Old 08-25-11, 08:26 PM
xwingzero2
xwingzero2's Avatar
everything is legit
but i must say how did u do your key ring dude? i taken it apart to wear the next steps leads me to take apart that loong piece below the wood grain a/c. So then i stop because what if i fk it up u know?
Old 08-25-11, 08:48 PM
OG Dada
OG Dada's Avatar
I didn't take any of the dash out, because during this time I didn't know how to take it apart yet. I just lifted the part covering the key cylinder and worked on it from below. There's only one screw for the transparent part of it, once you get to remove it you can take the key cylinder apart in 2 pieces to be able to access where the bulb is plugged.
Old 08-26-11, 02:06 PM
xwingzero2
xwingzero2's Avatar
^ ohhh okay i was afraid to lift that part lol. so is the bulb already white with the green sock over it? or did u just take the whole thing and put a new led bulb.
Old 08-26-11, 02:43 PM
OG Dada
OG Dada's Avatar
It's an ugly bulb with a green condom on it just like the one used for the glove box. Yeah I used an LED, much more cleaner and brighter looking.
Quick Reply: LED upgrades/conversion
