SC- 1st Gen (1992-2000)
changed maf = supercar!!!!! explain
Old 03-24-11, 07:08 AM
  #31
boney31
boney31's Avatar
when the fmz3ayy1 is in it makes the supension real tight. thats what i men with feel road more. any way i knew i wasnt crazy look at this.
http://www.celicasupra.com/forums/ar...p/t-56094.html
i just scan through it an i think fmz3ayy1 is rated at 190hp compared to fmz3ayy2 rated at 155-160hp this is maybe reason for better performance.
what u guys think.
will some one else try it because im telling u theres def a huge diff.
Old 03-24-11, 07:25 AM
  #32
drft_n_sc
drft_n_sc's Avatar
Originally Posted by BenStoked
the thing about the 1uz maf on another motor is not the sensor, but the size of the housing. the jz/7m housings are about 1/8-1/4 inch smaller diameter. larger diameter=more air in. upgrade the injectors at the same time, or you'll go lean, really, really badly.
7mgte and 1uz sensors are the same. I believe the 2jzgte has the same sensor, too but haven't worked on one to be sure.
Hey Ben yes the actual sensor is the same but like you said the housing on the 1uz is larger.
Old 03-24-11, 11:09 AM
  #33
MongooseGA
MongooseGA's Avatar
I still don't understand how the mass air flow sensor can have any adjustment over the suspension.
Old 03-24-11, 02:33 PM
  #34
redhot91gt
redhot91gt's Avatar
I think you might be imagining things..
Old 03-24-11, 04:57 PM
  #35
boney31
boney31's Avatar
lol awe man. try it then u will be the one posting telling everybody there r other alternatives to get proformance. im in ga if any one would like to come see for self
Old 03-24-11, 07:06 PM
  #36
MongooseGA
MongooseGA's Avatar
I was reluctant to point anything out, since I don't know exactly what suspension you have, but if it's stock or just on springs/shocks or coil overs, the MAF has literally nothing to do with the suspension.
I was considering that maybe you could have had a suspension that would adjust dampening or height based on speed, but I'm guessing no.
The suspension change is either a placebo effect, or the bumps you're hitting while driving as if you just tossed a bigger turbo on your car instead of a new MAF.
Old 03-24-11, 09:02 PM
  #37
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 03-25-11, 08:29 AM
  #38
drft_n_sc
drft_n_sc's Avatar
Man you all love making people feel stupid ... the guy probably meant his car feels more responsive ... If I remember correctly all he wanted was some insight as to why his car would be feeling like an entirely different car when all he did was swap out his MAF. There is no need to bash on how he chose to describe the performance of his car.
I'm not trying to be a **** but these forums are to help everyone out and small questions should be answered in a respectful way and not discourage anyone from asking any more questions in the future.
Old 03-25-11, 10:15 AM
  #39
Ali SC3
Ali SC3's Avatar
what maf is the one you swapped in actually from?? dont recognize all these part numbers.
if it larger in diameter it will lean it out some and you will feel like it is more responsive cause the c400 runs rich normally.
Old 03-25-11, 11:01 AM
  #40
User1321989
User1321989's Avatar
I agree, but then again people dont re-read what they write...therefore they get hammered....
Old 03-25-11, 11:16 AM
  #41
ckja
ckja's Avatar
how you know when your MAF is not working
Old 03-25-11, 12:02 PM
  #42
BenStoked
BenStoked's Avatar
um... yes?
Old 03-25-11, 01:12 PM
  #43
boney31
boney31's Avatar
the adjustment sounds more like it. like it sits on top of the wheel more or something. feels like your in power mode when in normal like tires really gripping the road.
an the bashing i could care less about cuz face to face there prob silent as a mouse.
Old 03-25-11, 01:14 PM
  #44
boney31
boney31's Avatar
i got it off of ebay an the listing said supra mk an ls400
Old 03-25-11, 04:52 PM
  #45
BartleDoo
BartleDoo's Avatar
You should try switching to MAP it makes the handling even tighter.
Quick Reply: changed maf = supercar!!!!! explain
