TDC on 92 2jzge plz help
how do i go about TDC on the 2jzge im thinking i have it wrong what marks do i look for bc on my cam gears i only have one mark per gear so i have them lined up with the mark on the black back cover were the marks are right on the top then the distributor i have the markes lined up then with the crank there are 2 marks i have the first mark lined up with the 0 on the plastic backing
hell the only hard part really on it was the balancer bolt i tryed all sorts on it tryed a braker bar with a 5 foot pole well guess what we broke the braker bar lol then we got a 500 foot pound impact gun didnt work went to a 600 didnt work then an 800 and still didnt work i had to grined the head of the bolt off to get the tension low enuff to spin it out then had to get a new bolt that bolt was a true pane
i also have one mark on my cam gears which i line up with the notches on the backing plate....
As for the crank pulley. it was aligned to 0 as well...
is that how it should be???
i will be seeking to change my distributor O-ring soon and i havent checked to see if the distributor was aligned to 1 in the cap when the markings on the cam gear are aligned to nothes on the backing plate..
my timing is definitely out though as we speak..
It sounds like your cam and crank is correct if you are seeing the crank at 0 and the cams pointing to the notches in the cam cover.
The distributor you need to align and insert when the motor is at TDC, you need the crank at 0 and cams pointing at the notches to inert it correctly. See below
you turn the crank to zero, then check that the cams marks are pointing straight up at the notch on the covers.
If they aren't, you turn the crank around one more time and then check again, now they should be pointing at the notch in the covers. if it isn't after the second turn something is wrong.
sometimes a picture is the best, and also has the distributor installation part.
thank you very much..... pictures are worth more than a 1000 words !!!!
iposted this vid in another thread about setting the distributor cap properly and where it should be aligned...
so after ensuring your TDC based on the pic posted.. i can follow what is said in the vid....
