How to: Trunk Lift Support w/ pics...
Old 02-20-09, 02:56 PM
  #211
JPSFAB
JPSFAB's Avatar
I just did mine right now...........it was so simple. Great write ups everyone............it definitely helped me out. oh yeah, I got mine from AutoZone for $10.38 each it comes complete with the new ball, washer, and the new rod. Man!!! what a deal. It only took me 10 min. to do both.
Old 02-22-09, 11:11 AM
  #212
gephross10
gephross10's Avatar
nice baseball bat. I'm using a yard stick before I have the time to fix this. Thanks for posting this, its very helpful. =]
Old 02-22-09, 05:36 PM
  #213
projekt
projekt's Avatar
for everyone who wants to go to advanced auto place you can get there support lifts for only 10.98+tax each. Just say autozone has it for only 10.98 and they will price match it. I had to wait only less then 24 hours. Ordered at 7pm and got it next thing in the morning. While at Autozone had to wait 4 days.
Old 02-22-09, 05:58 PM
  #214
buffalosoj
buffalosoj's Avatar
I got mine at advance autoparts also. It's nice to let the trunk up and not worry about getting hit in the head anymore.
Old 03-17-09, 04:54 PM
  #215
texan_176
texan_176's Avatar
Just did this today and it took maybe 15 minutes tops.
I used the Advance Auto parts version of the lifts and they are a perfect fit for my 98.
Having an open flame so near the gas tank and the wire that run near the area was out so I used a heat gun kind of like this:
http://www.harborfreight.com/cpi/cta...emnumber=66001
Heated for about 60 seconds they come off like there is nothing locking them at all. The other end just prys off with a screw driver. A 7/16 open end wrench installs the new ball and the strut just snaps on after that.
Great thread!
Old 06-03-09, 11:16 AM
  #216
BigManne
BigManne's Avatar
i just finished mine and it was fairly easy. thanks for all the info people. now i can "pop trunk on dem hattaz"
Old 07-01-09, 06:35 PM
  #217
felixsc300
felixsc300's Avatar
I don't mean to resurrect an old thread (I've posted a few times in here actually), but my luck hasn't changed. The two bolts still won't budge, even after I let the car sit out in the sun the entire afternoon in 95+ degree weather! I'm starting to get very frustrated. -_________-
Old 07-01-09, 07:08 PM
  #218
Amini9
Amini9's Avatar
did you spray a good amount of wd40 on it then trying to move the bolts?
do that and put ALL your might onto unbolting it justa little bit and it should give.
Old 07-02-09, 10:33 AM
  #219
One_jZ_SC3
One_jZ_SC3's Avatar
Wish I could "pop da trunk" as well...been messing with the bolts for over 1 week and these fu@^ers are beyond stuck...I just gave up..the new trunk supports are laying in the trunk on the floor
Old 07-05-09, 02:45 PM
  #220
RPH74
RPH74's Avatar
Have you tried a cheater bar yet? I have a 1½ foot long pipe about 1 inch in diameter that fits over a wrench, that has saved me on many such occasions.
Old 07-09-09, 09:41 PM
  #221
okbobbo
okbobbo's Avatar
Did mine today. Used a flame lighter on the bolt for about thirty seconds and off they came. Used an ice pick to pry off the clip on the other end. Used a rope from trunk lid "U" to the steering wheel to hold it up. Now it raises sometimes and sometimes not, even tho its the unit for the spoiler. Plan on unscrewing the bolt joint a turn to give the piston more oomph. Can't see where i could take any weight off the trunk lid to lighten. Looking for ideas. Thanks for all the write ups - they really helped.
Old 07-10-09, 12:52 PM
  #222
okbobbo
okbobbo's Avatar
Today I removed the ball joint ends, gave each two turns out and replaced. As for the bumpers, one was turned off to the side and the other was in the trunk in a bag of parts. Replaced both. The trunk now opens like a dream. Thanks everybody.
Old 07-11-09, 11:47 AM
  #223
One_jZ_SC3
One_jZ_SC3's Avatar
I might try this now since the bolts are now stripped lol!
Old 07-11-09, 09:07 PM
  #224
okbobbo
okbobbo's Avatar
Thought the lift problem was solved after unscrewing the ball end two turns, but the lid doesn't pop the first time. If nudged it goes up. If closed and tried again it goes right up and will continue to do so until left to sit awhile. Tried rubber conditioner all around the seal hoping it was sticking but made no difference. Might try another turn???
Old 07-11-09, 09:20 PM
  #225
PERRYinLA
PERRYinLA's Avatar
Default Give it up
You can turn it all day and night and it won't matter.
Who told you that "turning the ball ends" (whatever that means) would accomplish anything?
The lifts are not meant to always pop up the lid- sometimes you get lucky and it happens for a while on a new set, but eventually that stops working.
Quick Reply: How to: Trunk Lift Support w/ pics...
