SC- 1st Gen (1992-2000)
Quarter Mile Times
Old 03-24-12, 06:24 PM
  #61
MooJohn
MooJohn's Avatar
If you want your SC400 to have low end response, you have to cut the wire mentioned this thread.
In stock form, line pressure is bled off in first gear, during shifts, and on downshifts to make the experience more luxurious. It also does this any time the ECU thinks power delivery would make the rear end squat.
This mod is totally safe because it make it drive like every other non-Lexus that uses this transmission. The trans is happier because it isn't slipping and wasting horsepower that should be reaching the wheels.
I was going to use a relay so I could switch the wire as needed but I like it so much it's just staying cut permanently.
Old 06-01-12, 08:49 AM
  #62
92r154
92r154's Avatar
14.69 at 97.
Stock sc300 w/intake....and no cats...full tank of gas. and drivin my a** off
Old 06-04-12, 08:21 AM
  #63
BartleDoo
BartleDoo's Avatar
Originally Posted by 92r154
14.69 at 97.
Time slip?
Old 06-05-12, 03:21 PM
  #64
92r154
92r154's Avatar
scanner not working. 60 foot-2.19 330 foot-6.227 1/8- 9.523 1000-12.355 1/4-14.699@97.54
Old 06-08-12, 06:19 PM
  #65
armyastro
armyastro's Avatar
who uses a scanner anymore, snap a pic of it and upload
Old 06-20-12, 04:02 AM
  #66
Nova
Nova's Avatar
stock sc300, automatic. i was launching the car off the stall at 1500rpm track was unprepped but i would expect much more gain as i didnt spin.
Old 06-21-12, 11:10 AM
  #67
millertime
millertime's Avatar
um...
10.68@125 1/4
6.75@101 1/8
1.42 60 foot
Old 06-21-12, 11:36 AM
  #68
2JTsc300
2JTsc300's Avatar
16.7 with a slipping clutch all factory. in the process of doin soarer R154 swap and NA-T build
Old 06-22-12, 10:06 AM
  #69
Blakenz
Blakenz's Avatar
Soarer JZZ30 1jzgte with stock turbos 12.38sec at 110mph. best sixty foot 1.68(3600rpm stall convertor and mickey thompson ET street tyres) best terminal speed 111.87mph.(fastest/quickest stock turbo soarer in New Zealand) The car had a HKS f-con iS ECU, a shift kitted auto and a TRD LSD 2way diff.Running 110RON/100MON at 20psi.
JoshWhite
Build Threads
23
03-18-14 12:15 AM
socal300
Performance & Maintenance
07-06-08 07:22 AM
driftinfoo
15
07-31-05 10:38 AM
Quick Reply: Quarter Mile Times
