SC- 1st Gen (1992-2000)
Name that part!
Old 06-29-02, 03:08 PM
Neal Rikal
Neal Rikal's Avatar
Default Name that part!
ok, who knows what this is, if it can be removed and how?
Old 06-29-02, 03:18 PM
Lex Luthor
Lex Luthor's Avatar
Temp sensor for climate ctrl
Old 06-29-02, 03:43 PM
Neal Rikal
Neal Rikal's Avatar
damn
Old 06-30-02, 04:01 AM
Manaray
Manaray's Avatar
You can't mess with Lex Luthor bro...
Old 06-30-02, 05:33 PM
Neal Rikal
Neal Rikal's Avatar
i guess not you nailed that one
Old 07-02-02, 12:09 AM
1BomexLex
1BomexLex's Avatar
yeha... i dont think you wanna take that out
if you wanna move it.. you might could....
but i think lexus engineers know the best spots
Old 07-02-02, 07:46 AM
CmputerWiz
CmputerWiz's Avatar
If you remove it, the automatic air systems pumps hot air constantly. You can still use manual mode, but as soon as you turn the temp from COLD to 65deg, it starts blowing heat.
In case you're wondering, yes I tried it. Trial and error.
SR
Old 07-02-02, 08:26 AM
ForNgoods
ForNgoods's Avatar
Well i got one for u lex.. it's probably ez but i have no clue what it is.. on the upper right hand side of the dash there's this bubble thingy (yes that's the techincal name ) sorry i dont have a pic but i'm sure u know what i'm talking about.
Old 07-02-02, 09:23 AM
SC300T
SC300T's Avatar
I think its a solar sensor--also for the climate control. It is used to tweak the gain on the temp control when set to auto. i.e. really hot sun, it ramps up the fan speed slightly, etc. Its designed to compensate for the difference in human perception between 72 degrees in the shade v.s. 72 degress in the sun.
Old 07-02-02, 10:15 AM
AutoCoutureSC
AutoCoutureSC's Avatar
hey cmpterwiz, any way to fix that AC problem?
Old 07-02-02, 03:57 PM
pcmw
pcmw's Avatar
do-luck,
NO...the AC just relies on that sensor... if it is not plugged in the A/C assumes the car is FROZEN.
If your sensor is not functioning... pull off the ignition surround off, then the leather dash piece around the key hole... carefully check if the sensor is both plugged into the 2-wire black harness AND the air flow tube from the dash.
MW
Old 07-02-02, 05:00 PM
wwest
wwest's Avatar
Default resister
If you replace the aspirated (cabin air is "sucked" over the sensor)sensor, thermister, (that's what's behind the ventilation louvers shown in the picture) with 2.4 K ohm resister the system will "think" it's 72F ALL the time and you can control the outlet air temperature by how far you move the setpoint above, for heating, or below, for cooling.
Old 07-02-02, 05:09 PM
pcmw
pcmw's Avatar
Cool Trick WWest.
I found two parts that sound like the thermister you described above.
Air Conditioner, Automatic Temperature Control Components, Ambient Sensor, Sc300, Sc400 $47.96 List
Air Conditioner, Automatic Temperature Control Components, Inside Air Sensor, Sc300, Sc400 $21.10 List
Also found the black dash sensor
Air Conditioner, Automatic Temperature Control Components, Solar Sensor, Sc300, Sc400 $41.99 List
If you call youknowwho@youknowwhere.com you will probably get the thing replaced for cheaper than the resistor effort
thallium
05-01-19 03:33 PM
hovbuild
RX - 3rd Gen (2010-2015)
12-28-14 04:38 AM
lexluva
11-27-10 04:06 AM
DickM0823
02-06-08 09:31 PM
Floobydust
02-07-07 09:10 PM
Quick Reply: Name that part!
