SC- 1st Gen (1992-2000)
5spd Swap SC 400 Starts Today
Old 06-27-10, 12:42 PM
scENFORCER
scENFORCER's Avatar
^ What exactly is the CEL? And is this whats preventing our 98+ sc4's to be converted to manual?
Old 06-27-10, 01:05 PM
Vadim540i
Vadim540i's Avatar
^ Check Engine Light.
Old 06-27-10, 02:14 PM
scENFORCER
scENFORCER's Avatar
Oh, duh..
Is that something to do with why no one has attempted the 98+ manual? Or is it something else?
Which code is it throwing?
Old 06-27-10, 02:15 PM
HellFish
HellFish's Avatar
wonder how many codes would come up for the OBDII cars, with a manual swap.
Old 06-27-10, 03:13 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
ODBII car is gonna take a lot of work to make it "right".
Good luck!
Old 06-27-10, 05:08 PM
mtnrat
mtnrat's Avatar
Installed the clutch and pedals today. I had a ton of wires and a module for the anti theft-remote car start in the way. Took me a minute to figure out what it was. I just slowly kept taking things out of the way until I had a clear shot at the clutch holes. I used a battery powered tight angle drill. Made for easy drilling. I put a roll of paper towels to hold the clutch master cylinder in place while I worked away on the inside.
Where did others locate the bleed line for the howe bearing?
Old 06-27-10, 05:37 PM
HellFish
HellFish's Avatar
can you just run the bleed line along with the feed and zip tie it off near the master cylinder?
Old 06-27-10, 05:54 PM
tjfrom215
tjfrom215's Avatar
This is awesome, im hoping to do this by the end of summer, can't wait to see pics if your taking any!
Old 06-27-10, 07:25 PM
BartleDoo
BartleDoo's Avatar
Yea, mine has sitting up there for a month with no zip tie actually. Maybe I'll change that.
Old 06-27-10, 07:32 PM
RedPhoenix
RedPhoenix's Avatar
lol it doesnt matter, zip tie or not.
Old 06-27-10, 07:37 PM
mtnrat
mtnrat's Avatar
Some pics.
1. Using my next door neghbours shop
2. Parts
3. Tackling the console
4. Those hidden screws
5. Pilot bearing and pressure plate
Attached Thumbnails 5spd Swap SC 400 Starts Today-on-jackstands.jpg   5spd Swap SC 400 Starts Today-parts.jpg   5spd Swap SC 400 Starts Today-console-2.jpg   5spd Swap SC 400 Starts Today-console-screws.jpg   5spd Swap SC 400 Starts Today-pilot-bearing.jpg
Old 06-27-10, 07:50 PM
mtnrat
mtnrat's Avatar
more pics.
1. Howe bearing
2. The some anti theft wires were put right where the clutch master goes.
3. Clutch master interior pic
4. Shifter in
Attached Thumbnails 5spd Swap SC 400 Starts Today-howe-brg.jpg   5spd Swap SC 400 Starts Today-wires-in-clutch.jpg   5spd Swap SC 400 Starts Today-clutch-master-int.jpg   5spd Swap SC 400 Starts Today-shifter-in.jpg
Old 06-27-10, 08:05 PM
mtnrat
mtnrat's Avatar
When I installed the clutch master I cut away the padding into a square shape so the pedal assembly would easily go flush against the firewall. Sorry no pic. With the roll of paper towels holding the clutch master in place, I was able to get the drivers side nut on for the pedal assembly,(not much room), then the other nut and the top bolt.
Old 06-27-10, 08:21 PM
RedPhoenix
RedPhoenix's Avatar
Looking good bro!
Old 06-28-10, 08:14 PM
mtnrat
mtnrat's Avatar
I have everything buttoned up and was going to wait till tomorrow to bleed the clutch. I was checking everything out under the dash and noticed that the clutch master cylinder had leaked a little. I pushed in the clutch and sure enough some fluid leaked out of the rubber boot. So I guess I have to take that out tomorrow morning and see what the #$&% is going on. I was all ready to bleed it and test. Crapola.
Quick Reply: 5spd Swap SC 400 Starts Today
