SC- 1st Gen (1992-2000)
2JZGE Na-T TT Ecu Mod
Old 11-19-12, 09:44 PM
  #766
99SC42
99SC42's Avatar
What's wrong with your tps? Wasnt it working properly before you did these mods?
Old 11-19-12, 10:51 PM
  #767
duhafnusa4
duhafnusa4's Avatar
yea well it was, but the nissan tps on the q45 tb was bad, so i made an adapter plate and I am running the stock tps now, but i dont know what the base voltage should be
Old 11-20-12, 05:42 AM
  #768
ishootstuf
ishootstuf's Avatar
My car ran awesome for the 300 mile jaunt yesterday - but it still surges at really light throttle. Need to play with the TPS. I did hit overboost during a couple freeway pulls, so I dropped the boost. I also hit the speed limiter a couple times. My speedo is inaccurate and I didn't look at my NAV system when I hit the speed limiter, but I'm pretty sure its lower on the GTE than the GE because I hit 155 on the GE.
I can definitely feel a difference in how strong it pulls now that I got it on the open road. Damn... It never stops pulling! Feels great. If I haven't thanked everyone for their input on this mod - THANKS.
Old 11-20-12, 07:32 AM
  #769
Ali SC3
Ali SC3's Avatar
keep fiddling with it till it revs clean, mine was very touchy also.
yeah the speed limit on the USDM ecu's are like 150 mph something and on the JDM ecu's its 110-115 mph or something like that. hope the surge goes away, you can always try running a little less base timing it could be due to that as well, I am around 7 now last time I checked but I live a mile up in the air so your experience may vary also gas quality comes into play. glad mines not the only one that is pulling good. do you know what psi you hit the overboost.
Old 11-20-12, 09:42 AM
  #770
ishootstuf
ishootstuf's Avatar
Wasn't looking at the gauge, but I had been running ~15PSI. I wonder if the overboost kicks in after it overboosts for a few seconds, not just spikes. I backed my MBC off by 1/2 turn and never hit overboost again, but haven't looked at the gauge because I didn't care
My speedo is off by about 10% and it shut down at 110MPH, so yeah, around 120 I guess.
I may need to get an aftermarket tach too, because I keep banging the rev limiter in first as the tach can't seem to keep up with how fast the engine winds up.
Old 11-20-12, 10:31 AM
  #771
Ali SC3
Ali SC3's Avatar
lol, I know what you mean about the tach but you get used to the timing on the limiter and its a pretty soft cut.
I want to get a 6 spd ecu eventually for the increased rev limiter.
heres a teaser, guess whats going in that empty space?
don't mind the ps fluid, I need to change out alot of old hoses on this mighty 22r.
at least is doesn't leak oil anymore
Old 11-20-12, 01:04 PM
  #772
duhafnusa4
duhafnusa4's Avatar
soooo i think either my timing light or crank pulley mark is lying to me. I decided to time it my sound and feel instead of the light, and it runs so much better, no bucking, no dead spot at 4k, smooth idle.
am I doing the light at the wrong spot? i grab the signal wire from the first cylinder above the coil.
Old 11-20-12, 01:32 PM
  #773
Ali SC3
Ali SC3's Avatar
if you have vvti coils, you should have one of the coilpacks sitting on #6, with a wire lead running to cylinder #1.
you put the timing light clamp onto the actual coil wire going from the coilpack on #6 to cylinder #1.
If for some reason you installed your coils backwards and you have a vvti coil sitting on #1, you would use the coil lead going to #6 to do the timing off of, but you would have to have wired up the ignitor differently from what is in my thread.
basically your coils should sit on cylinders 2 4 and 6, and have plug wires running from 2 to 5, from 4 to 3 and from 6 to 1.
Also with vvti coils you must use a regular timing light.
If you have one of those "dial back" timing lights with the digital readout that you can adjust, it will not give you the correct reading it will give you double or half the real timing, i forget which way it is cause both are wrong.
Old 11-20-12, 01:49 PM
  #774
99SC42
99SC42's Avatar
The dial back timing light doesn't like wasted spark.
Old 11-20-12, 02:06 PM
  #775
Ali SC3
Ali SC3's Avatar
yeah its funny the $20 most basic timing light I ordered off amazon works perfect.
edit** looks like the price has gone up now its $35
Amazon Amazon
Old 11-20-12, 03:18 PM
  #776
duhafnusa4
duhafnusa4's Avatar
i have the supra tt coils and igniter
Old 11-20-12, 03:22 PM
  #777
99SC42
99SC42's Avatar
I told you guys about some crank pulleys having 2marks on them, a yellow one and a white one...
Old 11-20-12, 04:55 PM
  #778
duhafnusa4
duhafnusa4's Avatar
yea i tried looking for a second one, I can only see the white one
its pulls great now, but a check engine light comes on at full throttle in the higher rpms, code 31 for the map, any ideas?
oh and I just want to say the people (especially ali and quicksc4) are awesome, you help us people new to the na-t world out without looking down on us for doing something wrong, or making mistakes rep for you guys
Old 11-20-12, 06:43 PM
  #779
99SC42
99SC42's Avatar
Ok do you have another map sensor to try?
Or run new wires from the map sensor itself to the ecu , maybe you have some broken wires orthe connection is loose at the ecu.
Old 11-20-12, 10:22 PM
  #780
duhafnusa4
duhafnusa4's Avatar
i dont have another :/
I'll check the continuity of the wire I ran, as well as the connection at the ecu.
If those are fine I am guessing its the MAP sensor is bad?
Quick Reply: 2JZGE Na-T TT Ecu Mod
