SC- 1st Gen (1992-2000)
Dash brake light turns on and off?
Old 03-11-10, 10:38 AM
djrazr
djrazr's Avatar
Question Dash brake light turns on and off?
I noticed this morning that the brake(red) light on the dash will turn on and off, just randomly, as if i have the emergency break on.
How to fix this?
Old 03-11-10, 11:00 AM
bangdangvn
bangdangvn's Avatar
Other guys might know more but maybe brake fluid?
Old 03-11-10, 11:03 AM
1SICSC4
1SICSC4's Avatar
Check fluid levels. Then check you calipers.
Old 03-11-10, 11:13 AM
Photon440
Photon440's Avatar
I've had my brake light flash as well, and was just about to post about it. Mine comes on during a hard left turn and when I first saw the light I thought it was a low oil pressure warning. Then I saw it was the same light that comes on when the hand brake is applied. It goes off again a couple of seconds after the turn is complete.
My callipers, pads and fluid levels all look normal.
-=Photon=-
Old 03-11-10, 12:03 PM
willhickey
willhickey's Avatar
its the brake fluid , its probably that your pads are getting worn out and the fluid is seeping through them that is if they dont feel spongy. do your brakes feel spongy? i hate when that happens because your cruise control wont work whenever that light is on. dot 3 brake fluid is cheap so pour some in there man. order of elimination.
Old 03-11-10, 04:40 PM
ISALEX
ISALEX's Avatar
i would check the break fluid i had the same problem with my car and took it to the mechanic he poored on some break fluid and the problem whent away. good luck
Old 03-11-10, 07:52 PM
StiCk3
StiCk3's Avatar
brake fluid for sure. had this problem when i first got my car and a dash of brake fluid fixes it.
Scott610
IS F (2008-2014)
08-01-17 12:13 PM
armanitran
12-30-14 09:15 PM
ecstaticSC
Suspension and Brakes
11-15-07 06:05 PM
AaronE
Maintenance
05-12-04 09:50 AM
SLVRGS
GS - 1st Gen (1993-1997)
11-26-03 06:53 AM
Quick Reply: Dash brake light turns on and off?
