SC- 1st Gen (1992-2000)
Where's the Trans fluid fill hole?Am I dumbazz?
Old 01-27-10, 09:30 AM
mk4r34
mk4r34's Avatar
Default Where's the Trans fluid fill hole?Am I dumbazz?
I know it's probably a clueless question but,was doing a tune-up(plugs,wires,valve cover gasket,oil/filter/trans fluid) last night and drained the trans fluid but,can't find the fill hole? I've done searches,google etc. for an hour with no success??..I have a 93 5spd and I read these yrs. you can fill through the shifter but,I don't see any bolt or anything to fill through??....please tell me exactly where it is then call me a dumbazz"
Old 01-27-10, 09:35 AM
vwynn
vwynn's Avatar
the tranny dip stick.
edit: Dumbazzz.
haha jk
Old 01-27-10, 10:03 AM
Danimal
Danimal's Avatar
Filling the W58 trans can be done in quite a few ways.
The actual hole is about mid-transmission, on the driver's side of the tranny. You will have to jack the car up to get to it.
The way I did mine was to get about 6' of some clear silicone hose (I got it at Lowe's in the plumbing section). Don't go too wild in the diameter, I used 1/2". Went 6' so I knew I'd have enough.
Take off enough of the shifter assembly to be able to stick the hose through a hole to the bottom of the car, feed that into your feed hole on the tranny. Get back in the car, open up your gear oil, and fit it to the end of the hose, turn upside down and let gravity do it's thing. If it's really warm out, gravity should be able to take care of it. If it's cold, you're going to have to squeeze to assist.
I believe the capacity of the W58 is 2.7 qts. I spilled a fair amount, so I just did my 3 whole bottles (1qt each). You're basically supposed to go until the oil comes back out of the fill hole, but if your car is not level (i.e.: on 2 jackstands), you will end up over-filling it.
Make double extra sure you have the car on good jackstands.
If you have a friend and are absolutely confident in your jackstands, one of you can make sure the hose doesn't fall out of the hole, and the other can put the fluid in. (This is how I did it).
Hope it helps!
-Dan
Old 01-27-10, 10:04 AM
mk4r34
mk4r34's Avatar
edit: Dumbazzz.
haha jk
i thought that was on the 95+ or something...I can't find it on my 93
Old 01-27-10, 10:43 AM
MIGS
MIGS's Avatar
is it the same for Automatics?
i havent even checked yet, but might as well ask now so i will know when i go to drain/change my tranny fluid..
BostonSC4
BostonSC4's Avatar
i used my dipstick on my 93 sc400
Old 01-27-10, 10:57 AM
Danimal
Danimal's Avatar
The car the OP posted about is an early SC300, with a manual tranny.
I would guess all the autos have a fill tube in the engine bay, no idea though.
Old 01-27-10, 12:47 PM
HellFish
HellFish's Avatar
the fill hole is on the side of the trans. youll have to have a pump or one hell of a funnel to fill from the engine bay.
Old 01-27-10, 12:58 PM
mk4r34
mk4r34's Avatar
Right,I see two bolts on the side trans underneath is the fill the one with a sensor on it same size as the drain bolt?
Old 01-27-10, 04:13 PM
mk4r34
mk4r34's Avatar
Nevermind I got it...17mm bolt..used a funnel with a hose then ghetto rigged another funnel to go in the funnel...overall it worked
Michael
13
11-24-13 08:59 PM
g4ebguy90
Performance & Maintenance
03-17-12 02:50 PM
vegas_sc4
11-16-09 06:09 PM
fordsvtmfl
08-27-09 09:36 AM
HotBoy
Maintenance
12-30-03 09:09 PM
Quick Reply: Where's the Trans fluid fill hole?Am I dumbazz?
