SC- 1st Gen (1992-2000)
Need help with the stock alarm. Key does'nt unlock through the button
Old 01-17-10, 06:11 PM
platano47
platano47's Avatar
Default Need help with the stock alarm. Key does'nt unlock through the button
i put in a new battery on my sc300 key, its a 92 and i put the battery in and pressed the button and nothing happened. the doors did'nt unlock or lock, no lights flashed when i pressed the button....can anyone give me any leads?
Old 11-03-10, 12:31 AM
bkempf7
bkempf7's Avatar
i’m having the same problem. what kind of battery did you replace it with, because my screw came undone and i lost the battery.
Old 11-03-10, 12:48 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
It's a CR1216.
The lights don't flash on the pre-95's to my knowledge. Is the battery in upside down?
Old 11-03-10, 01:21 AM
bkempf7
bkempf7's Avatar
Originally Posted by Kira X
It's a CR1216.
sounds good. thanks!
Old 11-03-10, 01:32 AM
Cleanshots
Cleanshots's Avatar
um did ur knee bump the button that turns the remote off? NOOB
Old 11-03-10, 01:57 AM
bkempf7
bkempf7's Avatar
ha. assuming im the noob here, thats the first thing i checked
Old 11-03-10, 02:28 AM
CrazySC300
CrazySC300's Avatar
You know I'm currently wondering why that feature was removed from all the '95-'00 models....Instead, I have this homosexual looking blank panel in it's place.
Old 11-03-10, 07:23 AM
Klaus
Klaus's Avatar
^probably from people coming into lexus dealers wondering why their remotes don't work
Old 11-03-10, 08:18 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
Smile
That's probably it. When I got my SC, the switch wasn't turned on.
Old 11-03-10, 10:22 AM
BiGEZ
BiGEZ's Avatar
When I bought my car the remote did not work .I bought a Bulldog KE1702 keyless entry system off eBay for $35.00 and installed right next to the OEM keyless module. Works great. The unit even has the trunk pop and light flash feature if you get the additional relays. Easy to install, I used the 12v constant power supply from the oem unit and the 2 wire for the lock, unlock.
Remotes have dedicated lock/unlock button. If you want the horn chirp featuere get the unit with the alarm and just use the keyless part just like the KE1702.
S1w99
01-14-19 12:13 PM
funkymack
10-07-14 07:43 AM
skelow401
11-16-12 05:10 PM
Oo Meng oO
08-25-08 10:47 PM
hnwg824
09-28-03 07:35 PM
Quick Reply: Need help with the stock alarm. Key does'nt unlock through the button
